Re: [Complete Story] Gone Bad Party [1.0.9]
Here is the 11.9.0 release of Gone Bad Party.
viewtopic.php?f=8&t=311
For the female player, added a Talk option during intimacy with Derek or Frank (outside of Original Story scenes), in order to give access to a couple of more poses with them.
For the female player, added a fingering pose, as an option, when having intimacy with Derek or Frank (outside of Original Story scenes).
Added mechanism to restore roaming frequency of NPCs to be closer to one that was in the 1.0.6/1.0.7 versions of the game.
Other minor tweaks.
For those interested, this is how I am handling the roaming issue in Gone Bad Party in this thread:
viewtopic.php?p=10498#p10498
At least until the game is updated to restore the old roaming frequency.
French translation done for 11.8 is still valid for 11.9, as there is no text change.
Here is the 12.0.0 release of Gone Bad Party.
Main changes
Large refactoring of story scripts is done in order to utilize character groups and reduce the amount of repeated code. Hopefully, no new bugs are introduced due to this.
As a consequence of the above, I've slightly reduced the number of slang words used in the radial menu to refer to intimacy.
Completing the Silent Stranger expert quest will now give a permanent reward. For spoilers on this reward, see the strategy guide, which was also updated.
Permanent rewards are stored as CSC preferences, similar to how it is tracked if tutorial messages were already shown or not. The same setting for resetting tutorials can be used to delete this kind of reward.
Other changes
After the roof accident, the scene with a dead snake can be cleaned up.
Other minor tweaks and bug fixes.
By the way, character group refactoring affected much less of Gone Bad Party than originally planned, since most of the character group mechanics are only triggered for event actions that happen directly from the Radial action menu, and GBP has a lot of logic moved into event triggers, that can not benefit from this.
Plus, some of the event actions are not supported at this point to be used with character groups.
One major bug with character groups I've seen is that if you have some event action with a large delay to be used with the character group (to be executed with the same radial menu option for multiple characters) with a condition to check some character Value whose owner NPC is based on the character group, then criteria may not always execute correctly if the same radial menu option is executed multiple times with different NPCs in the short time frame (before delayed event action gets executed). As if the game loses the info when a delayed event is evaluated for conditions, which was the correct NPC that value was from.
Re: [Complete Story] Gone Bad Party [1.0.2.2]
This is for 12.0.x (HP 1.0.9) !
Original Story 12.0.x fr.zip
Mod for Original story
(765.07 KiB) Downloaded 684 times
Gone Bad Party 12.0.x fr.zip
Custom story
(765.07 KiB) Downloaded 670 times
Looks like the game update 1.1.6.1 stealth dropped on Steam and other platforms.
If you want to use this story, please roll back to game version 1.0.9 in order to not face issues, until I update the story.
Re: [Complete Story] Gone Bad Party [1.1.6.2]
Here is the 12.1.0 release of Gone Bad Party.
This is the first release that is compatible with the 1.1.6.2 version of the game.
The story is updated to match 1.1.6.2 Original Story, which includes things like separate freezer doors, Vickie entering through the front door, hiding items specific to future Liz Katz's DLC, etc...
Frank can get lucky with girls not only when sitting on his chair, but also during the sting operation. Still needs a girl with maxed out affinity to be involved with the player to get this available.
Frank can get lucky with the female player not only when sitting on his chair, but also during the sting operation. Still needs the player to be involved with one of the girls, but having 2 levels of affinity is enough.
Derek will not be blocked from having fun during the dance party in all the same situations when the player is blocked. For example, if the player has story sex with Leah (in POV mode), it will not block Derek from having fun with other girls at the dance party, while the player is blocked to do so.
Swapping of sexy collars can now happen even from make outs (no sex required).
Tweaked a bit the experience of the female player having POV sex with male partners.
Tweaked a bit what can be undressed during making out.
I've done some refactoring on when the girls will walk toward the player when starting sex or make outs.
Removed the workaround for NPCs roaming, since it is not needed anymore (the issue from the 1.0.9 update was fixed).
Fixed a rare edge case when Leah with affinity with the player can get annoyed in the middle of the snake hunt.
Fixed some issues when starting sex or make out with Rachael, if she is sitting on the flamingo.
Other minor tweaks.
The strategy guide is also updated.
Re: [Complete Story] Gone Bad Party [1.1.9]
Here is the 12.2.0 release of Gone Bad Party.
This is the first release that is compatible with the 1.1.9 version of the game.
The story is updated to match 1.1.9 Original Story, which includes support for the Winter Holiday pack.
Added support for Winter Holiday pack. The most notable change here is a slightly different way of undressing girls with sweaters, due to different clothing compositions. As well as restricting some poses during POV intimacy, when wearing sweaters, to prevent visual bugs.
Added small tweaks to the tablet, so it can be used even when held in hand.
Starting the dance party will now stop Stephanie from continuing lap dancing with Patrick.
Fixed the issue with Derek not leaving the dance party if getting in conflict with Frank.
Other minor changes.
