Intimacy command error
MissDemeanor
So after exploring all the content legitimately, I decided to mess around with console commands. I did some research and found a recently updated list. The intimacy command does not work for me in any way shape or form. This is an example of a string I used: "Intimacy Player Vickie 10050 Sexualact" The error code that returns is this: "Error: Looks like you have additional parameters or subcommands that didn't get used ( Intimacy). Instructions not clear....uhhh....hmmm...aborting!" Thoughts? I'm sure I'm doing something just slightly wrong. I tried switchign player and npc names and different intimacy codes and got the same thing every time. Thanks.
Re: Intimacy command error
Try in the console:
example intimacy
To see some examples of intimacy command.
MissDemeanor
Thanks very much. The info floating about seems to be out of date. Much appreciated.
