Sex sounds continue long after intimacy has finished
mada7
This is most noticeable when an NPC masturbates where it seems like the sound will loop from the beginning of a single long audio clip that continues well after the intimacy has finished. This also occurs with NPC/NPC interactions but not for as long as it lasts with solo intimacy
redwings16
Re: Sex sounds continue long after intimacy has finished
Amy does that for me but nobody else
mada7
I wasn't sure if it was Amy specific or not as I've been focusing on her story thus far for my custom story so thanks for confirming that for me
Yeah, it is known and annoying bug. And I've noticed it with all characters, when doing custom stories.
Only known workaround what I've found is that instead of aborting sex, you switch girl character to masturbation.
Then, you can easily add to her orgasm meter to be near the end, which will finish her moaning naturally.
mada7
peter980 wrote: Fri Apr 27, 2018 5:03 pm Yeah, it is known and annoying bug. And I've noticed it with all characters, when doing custom stories.
Thing is I have that problem worse with masturbation but I supposed I could try manually ending the orgasm
