Liz stuck in wall. Moveto not working
Sturok
Hello, Liz has been stuck in a wall for a long time. I've reloaded several times since.
I've tried the warpto command, but it only warps me to her instead of her to me.
>LizKatz warpto player . . tried rearranging but to same effect.
also tried unstuck Lizkatz /Liz
It seems the warpto command is broken?
Can someone please tell me a way to fix this?
Thank you
Shatteredhelix
Re: Liz stuck in wall. Moveto not working
Try the V2 console command:
unstuck.liz katz
or, if you're so inclined, the V1 command
unstuck "liz Katz"
Since Liz Kats is the only character that has a space in her name, if you're using the V1 console to unstick her, you have to follow the V1 console rules of putting things that have spaces in their names in quotation marks, like "Derek's Shirt" "Natty Lite" "Liz Katz"
The V2 console doesn't have this limitation, so it should be a simple matter of unsticking her by typing the V2 command above.
The quotation marks also apply to the warpto command, so
"Liz Katz" warpto player
should work. Keep in mind that the warpto command disables achievements while the unstuck command does not, if that kind of thing is important to you.
Last edited by Shatteredhelix on Sat May 25, 2024 2:03 pm, edited 1 time in total.
Sturok
Thank you so much for the detailed explanation. fixed issue and now I understand commands better
Appreciate it !
Sturok
I went looking for these v2 console commands and couldn't find them. Do you have a link by chance? thank you
Shatteredhelix
As a matter of fact I do, I wrote an entire document about it. https://docs.google.com/document/d/1JJG ... sp=sharing
I would say the majority of stuff you would want or need is in there, but if you have any questions, feel free to ask them. I'm most reachable over on the Discord server, HTTP://Discord.gg/eekgames but I do pop in here from time to time. There is much more information and activity over there.
Sturok
Awesome! thank you so much.
