I teleported myself with intimacy!
Stevezxc
So I had tried and failed to use the warpto command to make myself go to where chicks were, abd could only use warpto to warp them to me or each other.
Then while I was in the middle of boinking a chick, I got lazy and tried using the intimacy command on another chick without stopping on the first chick. And it teleported me out to the yard where the next chick was to boink her. So intimacy command is the way to teleport yourself around the place and boink chicks in their native habitats.
using the command console accessed by hitting the ` key, then entering the below command will teleport you out to wherever vickie is and start fucking her. Or if clothes are all still on, maybe just teleport you to her and stand there until you hit P or get everyone nekkid. Google house party cheat codes for more complete list. Also still fun warping the girls all together and making them bend over while you crouch or do other creepy things. But here's to teleporting yourself!
i
ntimacy player Vickie 10050 sexualact
clothing all all off
https://house-party.fandom.com/wiki/Cheat_codes
Orintangio
Re: I teleported myself with intimacy!
You will also find that by using 'Start BlowJob' that the chick will teleport to you. It's a way of moving around the room in mid romp and having the girls come to you, if they are in the way and blocking traffic.
I guess that's expected to avoid glitch where Player is in one room, doing nasty business in the air while NPC is in another doing the same.
In theory, you should not use console command to do anything. Your story has to move player and npc close enought to avoid such teleport issue.
Generally, intimacy is allowed only in specific spots in the house. So the player and his partner are teleported to the nearest such location.
Exempt for BJ/HJ, for which partner is teleported to the player.
Orintangio
Sometimes if I am doing doggy and want to in the opposite direction I will get BJ then switch to doggy. It will leave your partner facing how she was facing for the BJ.
