Cutscenes
Cutscenes
Is there a way to disable the sex cutscenes? For those of us who wanted the more interactive sex i mean, for example have seen that a few characters like rachael have a cutscene but after that you can't have sex with her again and it is not the interactive pov that i found enyoable from 1.18 and back
Re: Cutscenes
There will be an added functionality on this in the coming update my brah.
Re: Cutscenes
That scene is quite interactive, if you talk with her you can change position. It is not replayable. To fix it just use the editor and edit the story, it is very easy.
If you are afraid to mess with the quests just a couple of dialogues, one to send Rachael to bed and other to sex. You can also add a command in the wheel menu to have sex with every character everywhere whenever you want, you could also add some command for clothes too.
Re: Cutscenes
Those are great suggestions my brah, thank you!
Re: Cutscenes
Don't forget there IS a way to have repeatable sex with Rachael, you just gotta unlock it
