Ashley Approach Error
batosiz64
I am running into an issue where Ashley keeps approaching me after Julius Squeezer escapes, but will not initiate dialogue. I have tried restarting and loading from an earlier save, but the issue persists. I am currently running 18.2 and have attached a screenshot of the debug menu showing her repeated successful attempts to approach without engaging dialogue.
Has anyone run into this issue? Any recommendations on how to work around it?
Debug Console Log Showing Repeated Ashley Approach
Screenshot (1).png (1.98 MiB) Viewed 8754 times
Re: Ashley Approach Error
Do you have a save file relevant to this that you could attach? Thanks.
Maryceusz
erasmus wrote: Tue Feb 16, 2021 10:26 am Do you have a save file relevant to this that you could attach? Thanks.
So, I'm not the guy, but I also encountered this error.
Here is the save.
1.7z
(1.29 MiB) Downloaded 396 times
Maryceusz wrote: Mon Mar 01, 2021 8:09 am So, I'm not the guy, but I also encountered this error.
Here is the save.
1.7z
I see what could be causing it, but can you detail how you arrived at this point? Thanks.
Maryceusz
erasmus wrote: Sun Mar 07, 2021 12:36 pm
Here is the save.1.7z
I pretty much followed this walkthrough, until this point, where I got stuck:
https://steamcommunity.com/sharedfiles/ ... 1283977160
(Leah, Part 1 is where the snake part is).
markiez
Is the snake problem been sorted yet mybruh?
Maryceusz wrote: Sun Mar 07, 2021 2:03 pm
Alright thank you. I'll have to give this a run through and see if I can reproduce it. Did you also save/load exactly where the author instructed you to save/load, or did you follow a more direct path through the non-optional parts of the guide?
Maryceusz
erasmus wrote: Wed Mar 10, 2021 10:09 am
I pretty much followed it 100%, but I maybe picked up some items before they were required.
