Console Command not working?
So probably the smallest issue I could have, but sometimes I just wanna see some tits while playing, however whenever I try to use the remove clothing command at all, no matter how I try to switch it up, reword it, it doesn’t working anymore saying I either need to provide an int value or must specify a clothing option, even though I’m using the command exactly the same as I used to. Any idea wtf the issue is?
Re: Console Command not working?
What specifically are you inputting? Did you look at the help text? Try using (no quotes):
"help clothing"
"example clothing"
"help clothing"
"example clothing"
