With the new peeing feature added, some minor suggestions to consider to improve it.
*If your penis is not exposed and you press '2', you can pee yourself and see a wet patch start to build. As you walk, a trail of pee can be seen dripping from your leg.
*Peeing on the carpet and couches can create stains that can slowly dry out.
*Be able to control the aim of your stream.
*If you pee in the toilet, hear a splashing sound.
*Pee on either the fire pit or the indoor fire to put it out and hear it smolder.
*When you drink to fill your bladder, have the bladder meter briefly fade in and out so you don't have to keep exposing yourself just to see how full it is. Also add a slurping sound every time you sip water.
*Maybe have the option of having the Bladder meter always appear on the UI regardless if you're exposed or not.
*Be able to also drink from the hot tub.
*Peeing on Madison's painting could ruin them with the paint starting to drip off.
*If you pee in the toilet and Madison sees you, not have her tell you to pee in a toilet ... which you're already doing.
*If you keep drinking after your bladder is full, you could get warnings saying you're feeling pain and then you could potentially die from water intoxication and get a game over.
Peeing suggestions
Peeing suggestions
Re: Peeing suggestions
Thanks! Some good stuff here, but we probably can't add all of it in.
It is rather intrusive to be forced to expose yourself to see certain meters, but we don't want to clutter the UI. That's been a bother for awhile.
Anyway, we'll do what we can!
May not be a bad idea to temporarily show the meter, while drinking stuff, for couple of seconds.
Having pee on carpet and furniture leave a stain would be cool if you can do it! Also I like the idea of peeing on the paintings making them run. (Doesn't have to be interactive could just change to the peed on image when you do it.Though having it be interactive with the part you pee on running would be better. That would be more work though.)
Could you pee on the painting and then have something under the paint be revealed like another painting or else some writing of some sort that might be a clue to solving some other part of the story.
265lutab wrote: Sun Oct 18, 2020 5:40 pm Having pee on carpet and furniture leave a stain would be cool if you can do it! Also I like the idea of peeing on the paintings making them run. (Doesn't have to be interactive could just change to the peed on image when you do it.Though having it be interactive with the part you pee on running would be better. That would be more work though.)
That's a bit tougher, probably not. But we'll keep the general idea in mind for future content in House Party and Office Party.Broozer wrote: Sat Nov 14, 2020 10:56 am Could you pee on the painting and then have something under the paint be revealed like another painting or else some writing of some sort that might be a clue to solving some other part of the story.
Some great suggestions. All that trouble to add peeing, and really limited use for it currently. Would love to see all those items in the list, as well as preferences for watersports added to NPCs, such as like/dislike/tolerate.
It would be great if there was a game mode with more pee stuff in it. girls peeing on the floor or furniture in the party.
Thank you for your suggestion. We'll take these under consideration, we might also use this idea for Office Party. Brahprecciate it.
