Grumps and Derek stuck and can't be interacted with. (0.16.5)
wordyconch
Both the Game Grumps and Derek are stuck doing nothing and can't be interacted with.
When I try to talk to then it says that the Grumps are doing their thing (Grumps) or Derek's attention is on something else (Derek).
I haven't done anything special except save and load. It might have blocked when their event was on standby waiting for me to approach and I saved/loaded the game.
I don't really mind the Grumps being stuck but I need Derek.
Is there a way to reset Derek's AI or tell him to stop focusing on the grumps.
I've added an image to show their location and my output log.
output_log.txt
(96.15 KiB) Downloaded 359 times
Re: Grumps and Derek stuck and can't be interacted with. (0.16.5)
This will be fixed in the next update. BGC that is intended to be chained/queued in sequence can break on save/load currently, which means when you load, you won't see the next BGC that contains an event that would have freed all three characters. Sorry about that. If you want, I can help you fix this with a console command, but that will disable any Achievements for your playthrough.
