I can't to talk anyone and also no oppotunity after new update and I already solve every solution that dev are suggest to done but it's not functional
i.e. it happen after new patch update.
my dxdiag cause that I can't attach this files that I have to paste there
can not to talk to anyone and also no oppotunity after new update
- ภาพหน้าจอ (5).png (2.09 MiB) Viewed 9665 times
- ภาพหน้าจอ (4).png (2.12 MiB) Viewed 9665 times
- ภาพหน้าจอ (3).png (2.18 MiB) Viewed 9665 times
Re: can not to talk to anyone and also no oppotunity after new update
The screenshot you sent doesn't use english name. I suppose, your windows locale and parameters are also not set to be english or latin-based.
Could you try to change the locale and settings of your windows to english before starting the game, just to be sure your issue is not linked to your locale ?
To do so: https://www.tenforums.com/tutorials/132 ... -10-a.html
thank you the problem is date format but in my notebook use thai time and date format and can play in last patch.
Wait, so just to be clear: you have two computers that use Thai date/time format, region, and language, and one of them can play and the other cannot?vecpisit wrote: Wed Apr 08, 2020 4:56 am thank you the problem is date format but in my notebook use thai time and date format and can play in last patch.
if that's true, it's really odd.
In such case, could you provide the exact windows version you're using ?
To do so, just open a console Ms-dos and report the full first line. Please also add if this is a 32 or 64 bits version and if it's pro or familial one.
