Stop Stephanie from moving?
MaschaX
Hi!
I've been playing around with the new console commands (V2).
Is there a way to stop Stephanie from moving to her usual place inside or outside by the pool (not temporarily like the "let's hang out" option, but permanently disable her undying desire to go to her dance spot)?
I've diabled roaming already but that doesn't seem to do the trick.
Thanks for your help
MaschaX
Re: Stop Stephanie from moving?
Nevermind, found it.
stephanie.states(Immobile)=true
did the trick.
You can also try to find which periodic event is making her walk to dance room or outside.
then use:
events stephanie <name-of-event> setenabled false
Update:
I think it is: WalkTo-IntendedDanceArea
So use:
events stephanie WalkTo-IntendedDanceArea setenabled false
