So the game works great and I am still enjoying it. Speed of everything seems fine to me, but no matter how I change the graphics settings I get message of low FPS and FPS showing around average of 10-13. Finally turned off low FPS message.
Win 10
HP i7 laptop
Intel UHD 620
Again game runs great, but not sure why it gets low FPS. If I turn off certain settings I get 20 FPS at the highest and my setting is set to low. It has run some graphic intensive games like the latest Doom. I could technically play on ultra and be fine, except the game occasionally freezes only when I try to escape to the main menu, so I keep it on low.
Low FPS 0.13.3
Low FPS 0.13.3
Re: Low FPS 0.13.3
I hear you. I have a GTX 1080 and I am usually able to get 60 fps and even then sometimes frame rate just drops drastically for no obvious reason.
Also, I am not sure if the same true with you but in my game, lip sync seems way off even when there are no frame rate issues. It almost looks like it is caused by frame rate. Fiddling with setting yielded no results whatsoever.
Re: Low FPS 0.13.3
try checking for updates to your drivers i've had that happen at times usually an updated driver solves it
Re: Low FPS 0.13.3
Ouch... I hate to be that guy, but this is way too low to be able to run this game.
Re: Low FPS 0.13.3
I have my drivers up to date and the graphics card supports direct x 12. Graphics memory is showing 4 GB as well, which is the recommended settings. Granted more could be at play.
Re: Low FPS 0.13.3
I didn't want to say it... I really didn't want to say it.peter980 wrote: Sun May 12, 2019 7:27 pmOuch... I hate to be that guy, but this is way too low to be able to run this game.
Re: Low FPS 0.13.3
Re: Low FPS 0.13.3
I don’t get it, mine supports what is the recommended Steam page settings of Direct x 11, 4gb graphics memory. Granted it’s not the best graphics card out there.
My laptop also supports the 8GB of system ram.
Re: Low FPS 0.13.3
What you have is an integrated graphics processor, not a separate graphics card. Good for some basic stuff, but not really great for gaming. That is not to say you can't game on it, you certainly can, but you just wont really have the greatest experience.
Even with my 1080, frame rate drops sometimes. I can't even imagine how well it would work with integrated graphics.
Re: Low FPS 0.13.3
That is true. Too expensive to get the latest and greatest, for me, plus I prefer a laptop with mobility. I guess I should just be happy it runs, remarkably well despite that, and can play it. Not a complaint by any means, but wanted to mention in case the developer can smooth things for all players.
