[0.12.3] Patrick Glitches Into Wall
BlazR
When Patrick woke up from being knocked out by Madison in the living room, he ended up inside the wall. He was directly next to it when he was knocked out.
System Specs: Windows 10 Pro Version 1803 (OS Build 17134.407), AMD Ryzen 7 1800X CPU, 64 GB RAM, Radeon R9 290 (Sapphire Vapor-X OC Edition) GPU
Re: [0.12.3] Patrick Glitches Into Wall
1) Open console (~).
2) Type: unstuck patrik
3) This will not affect achievement gains
BlazR
peter980 wrote: Sun Dec 16, 2018 5:28 pm 1) Open console (~).
Gotcha. I know it probably isn't something they can fix since it's a weird object collision issue that only happens under certain circumstances. He shouldn't be able to get through the wall in the first place, but I think his colliders are all weird when he's standing up from being knocked out, which is always amusing to watch.
Yeah, there are some collider adjustments that occur as part of intimacy, combat, etc. but he SHOULD be getting kicked back out into a navigable area. As Peter said the unstuck command helps a lot for now, but we'll keep looking into this.
