Meltdown quest - water bottle
Posted: Wed Dec 27, 2023 4:48 am
by RukiRG
Hi guys
I have a problem with Meltdown quest. I had a look everywhere and i couldn't find a solution. Basically I'm stuck in Meltdown quest when we have to fill empty vodka bottle with water. I collected it earlier in game by tricking Frank to leave his spot and steal everything from cabinet. Now I was supossed to inspect the bottle from cabinet and ask Frank if I can take it. After that to use the facet/sink to fill it with water, but as you can see in attached screenshots i'm unable to do it. Is any other solution for it? Any console command to add the bottle of water in inventory? I already tried to add it by console command, but I couldn't find it. I only managed to add washer, whale poster or hammer.
Cheers and sorry if I posted in wrong section
Thank you
Re: Meltdown quest - water bottle
Posted: Thu Dec 28, 2023 6:09 am
by wargod
Same problem.
Posted: Thu Jan 04, 2024 8:19 pm
by RukiRG
wargod wrote: Thu Dec 28, 2023 6:09 amSame problem.
I finally solved it. Try to point your cursors to the left, under the cans hanged on the wall. Possible a visual glitch or misplaced target
Posted: Thu Feb 22, 2024 10:56 pm
by salmawisokya
RukiRG wrote: Thu Jan 04, 2024 8:19 pm
Okey :mrgreen:
Posted: Mon Jun 30, 2025 10:59 pm
by charliecohen
RukiRG wrote: Wed Dec 27, 2023 4:48 am Hi guys
Thank you, @space waves
Stuck in Meltdown quest – can't fill vodka bottle with water. Took it early, now interaction won’t trigger. Any fix or console command?
