1. I assume that the erection & open labia "emotes" are incomplete code that don't actually do anything at the moment? I was fooling around with the command window in the game itself and there didn't seem to be any actual activity when I set those emotes to 100. I even went down on some of the lovely ladies to get the best possible view, and there was absolutely nothing happening down there when I alternated between openlabia 0 and openlabia 100.
Likewise, the erection command didn't seem to have any effect whatsoever on the guys. But then, I guess that happens from time-to-time, right?
2. What's the actual command that triggers the game to present you with the welcome screen for Madison's phone, after you've gotten her password? In-game, you click the "Inspect" option to get the welcome screen, but I've been exploring the original story (21.1) in the CSC, and I can't see which event under the phone's "Inspect" option would trigger the phone interface.
3. With the RandomizeIntValue function, there are two unexplained parameters. Am I correct in assuming that these parameters define the minimum possible value (inclusive) and the maximum possible value (exclusive) for the output? That tends to be the convention for setting boundaries in computer programming.
