Amy kitty underwear through Console commands
rinshun
Hello,
I see the console commands for the clothing command got changed. (Now nothing makes sense) xP
I just want to know how to make amy wear her "goodbye kitty underwear"
Thank you!
Re: Amy kitty underwear through Console commands
Check
help clothing
example clothing
It should give you enough infornation to do this.
rinshun
It doesn't. It helps me get her top, bra, etc on and off. But not the alternate underwear.
I do agree, that this could get bit confusing.
For convenience, I copy pasted both help and example commands.
Help:
Clothing: Put clothing on, take the clothing off of, or change the default clothing set (where applicable) for an enabled character.
You will always need to specify an ENABLED character, or use the 'all' subcommand to specify using the command on all enabled characters.
You will then need to specify a clothing option (see below). Depending on the clothing option, you may also need to specify an item of
clothing (see below) or 'all' (strap-ons ignored by 'all'), an on or off value, and a clothing set. FYI, specifying an invalid clothing set may cause issues.
Valid clothing options are:
Change = 0, AssignDefaultSet = 1
Valid clothing items are:
Top = 0, Bottom = 1, Underwear = 2, Bra = 3, Shoes = 4, Accessory = 5, StrapOn = 6
Example:
Various examples of the Clothing command being used are as follows. To use them just type in everything shown AFTER the : (colon), and hit the Enter/Return key.
To change Amy's default clothing set to 1: clothing amy 1 1
To change Vickie's default clothing set to 1: vickie assigndefaultset clothing 1
To remove Brittney's top: clothing brittney change top off
To put Brittney's top back on: brittney clothing 0 top on 0
To take off Derek's shoes: change derek 4 off clothing
To take everyone's top off: clothing all top change off
To make everyone who can wear a strap-on put one on: clothing all 0 6 on 0
To experience the joy of the human body: clothing all 0 all off
One thing you are missing setting the correct "clothing set".
Any time you put clothing on, you specify a set, which can for now be only 0 or 1 (in red, in the example above).
It is not needed when removing clothing.
Clothing set is also specified when assigning what would be automatic hot tub underwear (in blue in the example above)
Only Amy and Vickie have clothing with set 1.
The help description is indeed a bit cluttered, listing almost all usages in a single sentence.
Also, it does not help that the example command does not list a single instance of putting on clothing from alternate set.
rinshun
BRUH...
Everything makes sense now. And I managed to swap undies
If anyone wants to know:
clothing amy change all off
clothing amy change bra on 1
