Re: [Complete Story] Gone Bad Party [0.19.4]
Not sure if I understand.
You play 0.19.4, using 7.0.0 version of Gone Bad Party, started as a custom story?
peter980 wrote: Fri May 28, 2021 5:16 pm Not sure if I understand.
I believe so. I will double check.
On your issue, it reminds me of a problem when multiple story files are in the same folder. So make sure if playing as a separate story that no "Original Story.story" file is present and that "Gone Bad Party.story" file is there.
Version 7.0.1 is out!
Updated some conditions for Simon Says opportunity so it is not immaterially restricted after The Muse opportunity is started, but instead only if progressed toward art exhibit scene.
Version 7.0.2 is out!
Fixed issue that would in rare cases break story progression if using tempt action on characters that are going toward the bed.
Version 7.0.3 is out!
Completing Simon Says will correctly mark Ashley's Smooth Operator opportunity as failed.
The strategy guide is also updated.
Version 7.0.4 is out!
Frank, if leaving the party, will drop the condom on the ground.
Tweaked a bit when the option to repeat intimacy with Rachel can show.
Original Story 7.2.x fr.zip
Mod for Original story
(611.88 KiB) Downloaded 243 times
Gone Bad Party 7.2.x fr.7z
Custom story
(464.06 KiB) Downloaded 304 times
Version 7.0.5 is out!
Minor balance tweaks.
Code refactor.
Version 7.1.0 is out!
Added options to unlock lap dances with Stephanie and Brittney.
Girls can more easily switch to making out during dance party when Derek is involved.
Added some "friendly" banter between some characters during group sex scenes.
Fixed "calm down" ability for Leah, so it now works correctly (it was broken since the 0.19.4 update).
Rebalanced some social stats gains with Vickie.
Restored some unused background chatter voice lines for Vickie (Original Story fix).
