Saved games sharing thread
Re: Saved games sharing thread
Save 7: Vickie's Test
Save7VickieTest.zip
(2.17 MiB) Downloaded 3316 times
This save continues on Save 5, by advancing Vickie's storyline.
1) Player is at the point where is he ready to pass Vickie's test.
2) Frank is knocked out by Derek and Patrick, and it is possible for Leah to stumble on Vickie's test and to choose to go with Leah instead of Vickie.
3) Player hooked with Ashley on her Smooth Operator path.
4) Player hooked up with Katherine.
5) Derek's Memory Lane path was started up to 3rd beer (roof scene finished).
From here, after you finish Vickie's test, you can get a special one-time intimacy cutscene with Vickie in the hot tub, or alternatively one time BJ scene with Leah.
After getting a sex scene with Vickie (instead of Leah), you will have the following repeatable threesome intimacy options available: Ashley, Katherine, Madison, Rachael, Stephanie, Frank and Patrick.
Repeatable basic intimacy cutscene is available with Katherine.
Repeatable POV intimacy is available with Ashley, Katherine and Vickie (if you did not do Leah path).
In VR, repeatable POV intimacy is available with VR Katherine and VR Rachael.
Save 8: Amy's Choice
Save8AmyChoice.zip
(2.18 MiB) Downloaded 2862 times
This save continues on Save 7, with two branching paths for Amy.
1) Story is at the point when you need to decide to continue Amy's Scavenger Hunt quest or abort it and pursue Chasing Amy path.
2) Player hooked up with Vickie.
3) Frank recovered from being knocked out.
4) Lety's story progressed up to a point where she searches for a female partner to hook up with.
You will have a one time BJ threesome scenario available with Lety and Brittney.
You will have the following repeatable threesome intimacy options available: Amy (if you complete the Chasing Amy path), Ashley, Katherine, Madison, Rachael, Stephanie, Frank and Patrick.
Repeatable POV intimacy is available with Amy (if you complete the Chasing Amy path), Ashley, Katherine and Vickie.
In VR, repeatable BJ is available with VR Lety (after the Lety's scene with Brittney is done).
Save 9: Amy in Hot Tub
Save9AmyHtub.zip
(2.18 MiB) Downloaded 3283 times
This save continues on Save 8, where Amy needs to do her last Scavenger Hunt task.
1) Amy and Brittney are in the hot tub at the end of Scavenger Hunt path.
2) Music is set up to play near hot tab and Stephanie is dancing there.
3) Player gained favor from Derek and can use it to have him flash Frank.
From here you can enjoy a spicy stripping scene in the hot tub with Amy and Brittney.
You will have a one time BJ threesome scenario available with Lety and Brittney. And Brittney will be topless in it (after you finish Amy's final task).
If Derek flashes Frank, and you opt to romance Frank, you can get repeatable a special intimacy cutscene with Frank in the bathroom. Alternatively, you can force Frank to leave the party.
You will have the following repeatable threesome intimacy options available: Amy (after you finish Amy's final task and have her stay topless), Ashley, Brittney (after you finish Amy's final task and Lety's scene with Brittney is done), Katherine, Madison, Rachael, Stephanie, Frank and Patrick.
Repeatable POV intimacy is available with Ashley, Katherine, Vickie or Frank (if you choose to romance him).
Save 10: Leah's Choice
Save10LeahChoice.zip
(2.18 MiB) Downloaded 2482 times
This save continues on Save 9, with a big branching path for Leah's story.
1) You are at the point where you need to decide what katana is for, in order to push Leah to a light or dark path.
2) Lety's scene with Brittney is done and Patrick was chased away.
If Derek flashes Frank, and you opt to romance Frank, you can get a repeatable special intimacy cutscene with Frank in the bathroom. Alternatively, you can force Frank to leave the party.
You will have the following repeatable threesome intimacy options available: Amy (if you get her to stay topless), Ashley, Brittney, Katherine, Madison, Rachael, Stephanie, Frank and Patrick.
Repeatable basic intimacy cutscene is available with Katherine and Lety.
Repeatable POV intimacy is available with Ashley, Katherine, Lety, Vickie or Frank (if you choose to romance him).
In VR, repeatable BJ is available with VR Lety (before sex in the bedroom).
In VR, repeatable POV intimacy is available with VR Katherine, VR Lety (after sex in the bedroom) and VR Rachael.
In VR, combat training is available with VR Leah.
In VR, a special encounter is available with VR Frank (if you choose to romance him).
Save 11: End State 1
Save11EndState1.zip
(2.19 MiB) Downloaded 3978 times
This save continues on Save 10, by finishing the evil Leah path and resolving the remaining storylines.
1) Leah's story was finished with her evil path.
2) Amy stayed topless at the party.
3) Lety's story was finished with hookup.
4) Frank's story was finished with hookup.
5) Derek's story was finished with hookup.
You will have the following repeatable threesome intimacy options available: Amy, Ashley, Brittney, Katherine, Leah, Madison, Rachael, Stephanie, Derek, Frank and Patrick (all available optipons).
You can have a repeatable special intimacy cutscene with Frank in the bathroom.
Repeatable basic intimacy cutscene is available with Katherine, Leah (if in the bedroom) and Lety.
Repeatable POV intimacy is available with Ashley, Katherine, Leah, Lety, Vickie, Frank and Derek.
In VR, repeatable POV intimacy is available with VR Katherine, VR Lety and VR Rachael.
In VR, a special encounter is available with VR Frank.
Also, you can unlock an Easter egg ending with Lety and Rachael, leading to a one-time intimacy scenario with both Lety and Rachael.
Save 12: End State 2
Save12EndState2.zip
(2.18 MiB) Downloaded 3789 times
This save continues on Save 10, by finishing the good Leah path and resolving some of the remaining storylines.
1) Leah's story was finished with her honor path.
2) Amy is still not topless.
3) Derek's story was finished on friendly terms.
4) Derek still needs to flash Frank.
5) Lety's is still waiting for hookup.
You will have the following repeatable threesome intimacy options available: Amy (if you get her to stay topless), Ashley, Brittney, Katherine, Leah, Madison, Rachael, Stephanie, Frank and Patrick (only Derek missing).
Repeatable POV intimacy is available with Ashley, Katherine, Leah, Lety, Vickie or Frank (if you choose to romance him).
In VR, repeatable POV intimacy is available with VR Katherine, VR Lety (after sex in the bedroom), and VR Rachael.
Also, after you hook up with Lety, you can unlock an Easter egg ending with Lety and Rachael, leading to a one-time intimacy scenario with both Lety and Rachael.
Save 13: End State 3
Save13EndState3.zip
(2.08 MiB) Downloaded 6621 times
This save continues on Save 8, by going for Chasing Amy and good Leah paths and resolving some of the remaining storylines.
1) Player hooked up with Amy on her Chasing Amy path
2) Player gained favor from Derek and can use it to have him flash Frank.
4) Leah's story was finished with her honor path.
5) Lety's scene with Brittney is done and Patrick was chased away.
You will have the following repeatable threesome intimacy options available: Amy, Ashley, Katherine, Leah, Madison, Rachael, Stephanie, Frank and Patrick (only Brittney and Derek missing).
Repeatable POV intimacy is available with Amy, Ashley, Katherine, Leah, Lety, Vickie or Frank (if you choose to romance him).
MelvinV
1.0 has dropped and I had made a guide on steam which resulted in me making somewhat around 17 save games.
I saw that the last upload was quite some time ago and decided to upload those same save game's here.
The full description of the save game's can be found both on the Steam guide: "Flowchart House Party + Save game's (MPC 1.0)"
Or in the .txt file's provided within the zip.
A short description of the first 14 saves in order:
1: When starting the muse quest
2: When you have done 1/7th scavenger hunt items
3: When you have Rachael's thermos
4: When you have Madison's phone back
5: When you have 4/7th Scavenger item's done
6: When you are about to give the topless picture's to Frank
7: When you have the Rum after Distracting Frank
8: When you have done 7/7th scavenger item's
9: When you are about to give Frank a full nude picture of Katherine
10: When you start Frank's story
11: When you start Leah's story
12: When you invite Lety
13: When you have Patrick's phone + Vickie's number
14: When you have to get tested by Vickie
These aren't completed but contain a lot of the prerequisites needed to advance with stories, For example save 6 allows to grab the thermos after completing Katherine's story, meaning you can immediately continue with Rachael.
Then I also have 3 completed save's which have all stories completed (except the game grumps):
Save 1:
Intimacy rewards unlocked: Rachael, Katherine, Derek, Madison (BJ), Leah (Dark), Amy
Threesome unlocked: None
Booze acquired: All, some given to Derek
Extra: Frank has been bullied away, he is no longer at the party
Save 2:
Intimacy rewards unlocked: Ashley, Vickie, Lety, Derek, Stephanie, Leah (light), Frank
Threesome unlocked: Derek, Amy, Brittney, Rachael, Madison, Ashley, Stephanie, Leah, Frank, Patrick
Booze acquired: All, Booze given to Derek, Ashley and Pot to Ashley.
Extra: Frank has been beaten by Patrick and Derek
Save 3:
Intimacy rewards unlocked: Amy, Vickie, Ashley, Derek, Katherine, Lety, Leah (Dark)
Threesome unlocked: Derek, Amy, Ashley, Madison, Rachael, Katherine
Booze acquired: All, Some has been given to Derek.
Extra: Frank has been bullied and is not present at the party
I have decided to pack all the save's into 1 big rar file: https://1drv.ms/u/s!Ar1htQWS8d2Lgcdk0ne ... Q?e=cnfwzN
