Re: [Complete Story] Gone Bad Party [0.12.4]
Version 1.17.3 is out.
Restricted some actions for Madison, Ashley and Rachael at several places in order to not break the story
Also added several fixes to original story content:
Fixed issue with getting overlap of pants and underwear at the end of Ashley prank reward scene, if you started the scene with only underwear
Fixed issue with getting pants back, blocking the ability to remove pants, at the end of either Ashley prank or smoother operator reward scenes, if you previously lost the pants due to conflict with Derek
Version 1.17.4 is out.
Moved alternate way of getting thermos using Vickie a bit earlier.
Tweaked Ashley prank and smooth operatror ending scene to reduce chance of some bugs.
Tweaked Katherine master bedroom scene to reduce chance of some bugs.
Fixed some issues with Stephanie "stargazing" ending.
Code refactor.
ixradioactivexi
Katherine seems to be missing from the latest release
Ouch... my bad. I have by error missed packing that file.
She should still be available if you play as override.
I'll update the story with the fix, as soon as possible.
I've updated the archive in the original post with corrected story files.
Now Katharine should appear correctly, if played as custom story.
Cherry
Great Story!
One question: I started the dance party and all girls are dancing in the living room, what is next? I only can stop it, do I miss something?
Baddieus
"One question: I started the dance party and all girls are dancing in the living room, what is next? I only can stop it, do I miss something?"
Once they are all 'Seduced' & 'Temped' you can have a 2nd Dance Party option allowing just about everything to happen on the floor with the group, including getting Derrek in on the action
ixradioactivexi
has the Simon says quest been removed?
It is still present in GBP, but there are conditions which will make it unavailable.
For example, if you raise affinity with Madison, or start Muse quest, it will not be available anymore.
Additionally, it is closer to original version from Original Story, so you can not do it if you already got quest to Humiliate Ashley, even if it could lead to getting unlocked phone at later time.
Version 1.18.0 is out.
Added one new opportunity. Not actually new content, just a hint to existing content that is a bit hidden.
Tweaked a bit tablet chat sequence, for clarity.
