Re: [Complete Story] Gone Bad Party [0.10.4] {CSC 0.7.0}
Then you have not installed it correctly.
Is story folder called "Gone Bad Party"?
.story file and folder name should match.
EcoWarrior42
It's installed fine.
... Apparently more progress is needed with the characters to get the option, not just to have a good chance of success ... but any chance at all requires "friend" status.
Seems like it was easier before, issue is probably the Dr. Stephanie route the blocks some of the other paths (Brittney).
Should all the characters have the ?option at some point? Or only a few?
EcoWarrior42
Although the pesky "teleport" issue between rooms with player and character.
EcoWarrior42 wrote: Tue Aug 07, 2018 10:23 pm Should all the characters have the ?option at some point? Or only a few?
All female characters should have ? options.
Each option has its own set of requirements (like for example, being alone, already intimate, not currently walking somewhere etc..).
Romance bar only affects the chance of success.
? options are almost never blocked by story elements, but intimacy actions that they unlock can be blocked. For example, you can not be intimate with Steph during Meltdown being in progress.
EcoWarrior42
Brittney & Vickie situations must be more complicated ... will keep trying things.
Thanks.
Updated to 1.5.2
Mostly tweaks to Madison's Simon Says opportunity.
Renamed couple of actions.
Code refactor.
Updated to 1.5.3
Just fixed original story bug I've encountered:
Resolved issue with increased orgasm sensitivity if you do not take advantage of Ashley during Derek/Madison scene, if Training Day quest is active
Updated to 1.5.4
No functional changes in this release. Just removed references to Original Story and added references to Gone Bad Party in character files, in order to support localization, if using story as custom story.
If using as override nothing is changed.
Updated original post, with the link to the post above with French translation.
Updated to 1.6.0
Added 3 quests to the story. These cover already existing activities in the story, and are added as a way to track them.
Fixed some issues with prerequisites for Swap action.
Fixed some issues with "Let's Lower Some Inhibitions" opportunity integration with activities in the story.
