Re: [Complete Story] Gone Bad Party [0.10.4] {CSC 0.7.0}
Updated to 1.4.2
Fixed issue with saving Stephanie dance skill value.
Made sure that player character looks correct when being shirtless with pants on.
RumRunner
DanL58 wrote: Sat Aug 04, 2018 2:53 am The issues with the girls getting stuck in walls has definitely gotten better with the new version of the game but it is still happening as you know. Why do the characters warp away after intimacy at all? Why can't they just stand up and continue the story from where they finished the sex?
The characters are on top of each other during sex and in order to allow your bodies to overlap, the collision code for the characters is turned off. After sex, the collision code is re-enabled, so that you can bump into each other again while walking. When the collisions are re-enabled, the game engine will be forced to resolve the collision, but the HP code might first attempt to find a valid location for the character, and if that's true, it isn't perfect at doing so yet.
I've only started looking at the code, but I've seen bits where the HP code does help find a valid location (just not sure if it's called after intimacy). Regardless, the act of resolving the collision is the most likely cause and results in this weird behavior. Instead of describing it as the character warping, it's more like a push or pull, as the colliding object (the character) is forced to move.
If the collision resolution pushes the character beyond the wall or under the floor and into a deadzone, or in your case, on top of the toilet, then Amy, the character in this case, is no longer on a navigable location and doesn't know what to do, so can't move on her own.
A good illustration of this is the blue area on the ground seen here: https://docs.unity3d.com/Manual/Navigation.html
DanL58
Not sure if this is a bug or not. I used your mod as an original story override this time and everything when fine until just about the end. After the porn audition with Madison, Ashley invited me to her room and she got undressed and got on her knees but I couldn't go farther with her. Clicking on her didn't bring up the dialog box anymore and I couldn't continue with her. I went back to the master bedroom, talked to Derek and he was telling Madison to come out of the bathroom. I unlocked the bathroom and went in with Madison. Clicking on her didn't bring up the dialog box either. I reloaded to just before the porn audition and ran it again with the same results.
This with done with version 1.4.0 with the dance party not running.
JohnC998
Stuck on trying to find something for Stephanie to breathe into during here panic attack, or some way to calm her down. Please help. Been at it for some time. Thanks. ;)
DanL58
JohnC998 wrote: Sun Aug 05, 2018 12:49 pm Stuck on trying to find something for Stephanie to breathe into during here panic attack, or some way to calm her down. Please help. Been at it for some time. Thanks. ;)
There is a paper bag outside.
DanL58 wrote: Sun Aug 05, 2018 9:32 am Not sure if this is a bug or not. I used your mod as an original story override this time and everything when fine until just about the end. After the porn audition with Madison, Ashley invited me to her room and she got undressed and got on her knees but I couldn't go farther with her. Clicking on her didn't bring up the dialog box anymore and I couldn't continue with her. I went back to the master bedroom, talked to Derek and he was telling Madison to come out of the bathroom. I unlocked the bathroom and went in with Madison. Clicking on her didn't bring up the dialog box either. I reloaded to just before the porn audition and ran it again with the same results.
I haven't changed anything with Approach option. Is that one you do not see?
There is Approach, when you pick a pose, and then afterward Fuck option to start sex.
Although the "hump" related options are disabled at that point for both Ashley and Madison, which is per design.
Send me a save and I could look what could be an issue.
DanL58
peter980 wrote: Mon Aug 06, 2018 12:19 am Send me a save and I could look what could be an issue.
I started a new game and overwrote my save file. Will have to let you know if I reproduce it. I upgraded to your latest version.
Updated to 1.5.0
Added options to meet at fire place or spare bedroom with Amy, at specific story points
Improved Chasing Amy ending (clothing and walking behavior in regards of spare room use)
Made sure that Ashley end sex triggers from original story do not trigger when playing new content
Refactored some code, including check to see if NPC is alone with player or not. Hopefully there are no side effects
Original story fixes:
Katherine will not get stuck in bathroom if poisoned, if Apply Pressure opportunity already failed before that
Updated to 1.5.1
Small hotfix to clothing behavior of Vickie when doing her tests from original story, when related to new content (making sure she never wears panties afterwards).
EcoWarrior42
"There are several actions that have question mark (?) in their name."
As of 0.10.4, when installed as a custom story: these options are no longer showing up.
(regardless of how far relationships have progressed).
