Story updated to ver. 1.22.066
  • added Breast Treatment room
  • improvements for Bathroom 3 procedure
:arrow: Important note for Breast Treatment: after you set girl for treatment over laptop, you MUST leave the room to trigger process.
As you keep track of number of blowjob/handjob, should you also keep track of cunnilingus ?
ttant wrote: Tue Apr 26, 2022 3:01 pm As you keep track of number of blowjob/handjob, should you also keep track of cunnilingus ?
Sure. I can add counter for that too...
Story updated to ver. 1.22.069
  • added cunnilingus counter
  • updated other counters too
  • updated info texts
  • small improvements in menus
French translation updated as well (for part which can be translated).
I am still having trouble with activating quests for wanting more. I get the first one when they get in bed. After that, no matter what I try, they will not ask for the 2nd one. However, if I get them in bed and make a sex call, the quest updates to 2/5. Past that, nada. Any tips?
That's OK. Only for the first time girl ask you about other parner. After that, it's up to you to use 'Sex Call'.
Danny wrote: Tue May 03, 2022 3:19 pm That's OK. Only for the first time girl ask you about other parner. After that, it's up to you to use 'Sex Call'.
Ok cool. Do you plan on adding any other quests? This is one of the rare mods with strapons so I look forward to see what more you can do with it.
Prome
Hello!! Here I leave you a translation into Spanish made by me for those who need it.
Read the notepad for installation
Hola!! aca te dejo una traduccion al español hecha por mi para los que la necesiten.
Leer el block de notas para su instalacion
traduccion al español.rar
(82.83 KiB) Downloaded 821 times
Story updated to ver. 1.22.071
