Important info regarding using 0.12.4 stories in 0.13.3
While these stories are mostly compatible as is, if author has used option to disable some event triggers during story, the disabled state will not get saved in the save game. So bugs on save game load could happen in some situations.
Note that importing to 0.13.3 CSC and reexporting should be all that is needed to fix this.
This happens since in 0.13.3 event trigger ID is used to track save state for them, and in 0.12.4 and before, event triggers had no ID assigned to them.
Ecolai
Re: Important info regarding using 0.12.4 stories in 0.13.3
Peter, do you mind me asking if you work for Eek LLC? :D
You have provided so much content!
Short answer: no.
But I do participate in testing during alpha and beta phases.
