Add a Garden Hose
Baddieus
Add a Garden Hose
I know this suggestion would take a bit of programming & extra graphics but ...
If there were a spooled garden hose out near the fire pit or on the side of the patio, then if the player exposed to an unfriendly they could grab & and say "you need to cool down" and spray the player. Or the player could be tasked for another prank on someone, or use it on Patrick to help him sober up or Stephanie could ask to be hosed down because of all this dancing making her sweaty. Further, if the player forgot to let go before walking to far they could get jerked onto their back with people who see it happen laughing or say things like "way to go dumbass"
cesidio
Re: Add a Garden Hose
Also another path to make Ashley undress: her clothes need to be put in the dryer.
This idea made me laugh, in a good way :) I can think of a few additional uses of a hose myself, but depicting a hose and water (required if we want to do this "right") accurately might be a lot more work than we can undertake for the foreseeable future.
I will compromise with you...I added a sequence for the next update where the player spews fire out of his ass (we already technically have fire assets). Is that a fair middle ground? It's...totally related... :P
odjntrade
You could also just make them splash water from a cup. Maybe after lighting someone on fire with your fart you could then splash them to put the fire out. Also, bonus mechanic that if you had alcohol in the cup it makes the fire better.
Kevner
I think it would be enough to have something like a water pistol instead. A hose would need a flexible model that reacts to the physics, while a pistol would only need a model that you trigger from the radial menu inside your inventory and fires out particles in front of you like the cum effect when the item menu closes. It would be nice having something to hold and aim but there's no precedent in the game so this way would surely involve less programming?
Continuing the idea; naturally there would be reactions (positive and negative, depending) when somebody is sprayed. Wet clothing is what we would want next, seeing bras or nipples as wet alternative textures would have to have separate clothing, but maybe the original meshes can be copied as a quick way?
Extra particles to play with, even just the pew pew style from before, would be my ideal addition. Water steaming from a shower head, with a move location set in the bath (and maybe hot tub style water in the bath if you select to fill it) would allow for some natural voyeurism scenarios. A step further if the toilets can be used as chairs and give the girls themselves some related particles?
Orphris
Water pistol idea above is great, I really like it. If we ever going to get something similar to this, that's the way we should do it.
AhzeeKing
He supported the idea of Kevner, it would be great to be able to spray with the water gun, it reminds me of the film of the fraternities.
redwings16
Kat is waring a white shirt maybe make it so it becomes transparent when wet?
