Is it possible to create an item ?
Nejiro
Hi,
I would like to create simple new items, like clothes per example, or panties etc...
I don't need new graphics, if per example I want Madison pantie, it can be the same as Ashley's
thank you in advance
Kind regards
Re: Is it possible to create an item ?
In current engine state, it's sadly not possible.
Nejiro wrote: Sat Sep 15, 2018 6:21 am Hi,
Kind regards
Do you mean something they wear? Or an interactive item just for an opportunity? As ttant said, if it is a wearable/visible item, no, not at this time. If it is just a quest item an NPC gives you, you can just handle that in the story files by renaming items and structuring the plot/dialogue/Opportunity in the right way(s).
cesidio
You can't even swap already existing items. A model is assigned with clothes at a precise position (you can mount Katherine's panties on her head like the glasses and you can't put her panties over the jeans) and can't be changed for now. I wonder if there are still clothes from the 0.4 version available among unused items.
