a98987
Re: [Complete Story] House of Lust - DMA [1.2.2.1]
如果有中文版就好了,毕竟中国玩家很多的,建议设置中文模式
a98987 wrote: Wed Dec 20, 2023 7:45 pm 如果有中文版就好了,毕竟中国玩家很多的,建议设置中文模式
viewtopic.php?p=9920#p9920
eekgameuser
Danny wrote: Wed Dec 20, 2023 2:07 pm
eekgameuser wrote: Wed Dec 20, 2023 10:27 am Awaiting your insturctions.
Open File Explorer and copy/paste below code in address field:
%AppData%\..\LocalLow\Eek\House Party\Saves
then... right-click and make .zip file...
lol..okay maybe not that much of an idiot. What I meant was where do I post the save file and if it's on discord I'm not sure how to go about doing that.
The version of the game I am playing is ver 2.15 - 1.2.2.1
In further testing I have graduated a few more npc's to Team player status and there are no problems using the Group Sex option but as soon as I go back and try the scenario I originally reported there is still npc entanglement that prevents the opportunity from advancing.
By the way, have a happy holiday.
eekgameuser wrote: Thu Dec 21, 2023 9:40 am What I meant was where do I post the save file and if it's on discord I'm not sure how to go about doing that.
Just post it here as attachment...
eekgameuser
Danny wrote: Thu Dec 21, 2023 9:43 am
Sure appreciate your patience in this matter. I have attached a zip file that contains 4 save files prefixed with GS1 - GS4.
GS1 and GS2 are a related set and GS3 and GS4 are a related set.
The first save of each set is so you don't have to do anything other than load and observe.
The second save of each set is so you can experiment with different NPC's. You need to start the Group Sex Menu to proceed.
Set 1:
GS1 Bedroom Locked Door - No interaction required! Group Sex Straight. Player, Amy, Ashley, Katherine, Derek and Frank.
Result Frank becomes entangled with Player and Ashley and NO Team Player Opportunity.
GS2 Bedroom Menu Ready - Ready for Group Sex Menu. Allows choice between Frank, Derek and Patrick.
Result - regardless of choice player and npc become entangled and no Team player Opportunity.
Set 2:
For the next test I added Madison. I changed Amy's orientation to Asexual.
GS3 Madison Locked Door - No interaction required! Group Sex Straight. Player, Ashley, Katherine, Madison, Derek and Frank.
Result Group Sex is successful and Team Player Opportunity advances.
GS4 Madison Menu Ready - Ready for Group Sex Menu. Allows choice between Frank, Derek and Patrick.
Hope this helps. Again sure appreciate all your help!!
TestGroup.7z
(1.95 MiB) Downloaded 637 times
eekgameuser wrote: Thu Dec 21, 2023 11:49 pm Hope this helps. Again sure appreciate all your help!!
Fixed.
Story updated to ver. 2.16-1221
  • Group Sex, bug-fix
eekgameuser
Danny wrote: Fri Dec 22, 2023 3:36 am Story updated to ver. 2.16-1221
Thanks. Works great now.
eekgameuser wrote: Fri Dec 22, 2023 7:16 am Thanks. Works great now.
No update required for french translation.
