No "StoryCollection" script in file "HPCSC.0.16.5.zip"
ANONYMOUS312
I made all in the guide but the .zip file doesn't contain "StoryCollection.cs". Is it bug or i need for use script from other version?
P.S. I'm new in custom story creator but i'm old in Unity.
Re: No "StoryCollection" script in file "HPCSC.0.16.5.zip"
In theory, just extract the csc somwhere and load that folder as unity project.
Once the csc has tsarted (for teh first time only) double click on the expected file and that's it.
Only errors i saw was due to wrong unity3d version used as backend.
ANONYMOUS312
I got "HPCSC.0.16.5.zip" file here:https://forum.eekllc.com/viewtopic.php?f=9&t=65.
For understand me you need for create new Unity project and import story folders as instructions. In any objects will be "Nothing selected" panel. This panel needs for script, but .zip package hasn't any scripts. Is it bug?
P.S. My Unity version is 2017.4.0f1
erasmus wrote: Fri Feb 23, 2018 4:55 pm FYI we are now on Unity 2018.4.19f1.
You have to update your unity3d setup then try again.
Did you fully extract the CSC files to location on your computer before opening the CSC Project in Unity?
ANONYMOUS312
erasmus wrote: Fri Jul 17, 2020 9:46 am Did you fully extract the CSC files to location on your computer before opening the CSC Project in Unity?
Of course, I making games in Unity 4 years. I got 'no script' field. And really, I not found script
ANONYMOUS312 wrote: Sun Jul 19, 2020 8:18 am
Can you provide a screenshot of what you're seeing and exactly where you're seeing it?
ANONYMOUS312
erasmus wrote: Sun Jul 26, 2020 7:45 pm Can you provide a screenshot of what you're seeing and exactly where you're seeing it?
ttant wrote: Thu Jul 16, 2020 4:34 pm
You're still using the WRONG unity 3d version. :roll:
That may explain why some stuff doesn't load correctly.
It's like using windows XP applications on windows 10: some stuff doesn't work and need to be upgraded.
^^this is a very old version of Unity compared to what our recent CSC releases have used.
Also, not that this next point is guaranteed to be an issue or even particularly helpful, but if you're simply extracting the CSC folder to where you want to work from and loading that folder from Unity's project screen, the name of the resulting project would match the exported CSC folder name. Here it just says "New Unity Project (2)". Again, I see the scene and assets so this isn't necessarily an issue. However, when troubleshooting I'd suggest following the absolute simplest process, which is extracting the CSC directly to a folder and selecting that as your project.
