Hello,
I have a few questions regarding the orgasm meter for the Custom Story Creator.
Let's say I want to use an item like the painkillers for example, and on use I want it to do either effect A or effect B in my game (not both on the same item, maybe two different items, one doing effect A and another doing effect B)
Effect A: Consuming the item will cause the orgasm meter to raise slower than the default speed
Effect B: Consuming the item during the orgasm meter in resting phase (the yellow meter) will reset it back
Is there a way to do this in the custom story creator? If so, how would I go about to do this?
Orgasm Meter Modifying
Re: Orgasm Meter Modifying
Yes, there is.
Best example if Vickie storyline in Original Story.
There is variable called OrgasmSensivity for each character that defaults to 1 (for player) or 1.1 (for NPCs).
Higher values lead to quicker times, lower value (0-1) lead to slower times.
Good to know. thank you my friend!
