I can play other up to date stories, as well as the original and my game is up to date, i do have the same issue with gone bad party as well though, but Katherines party, an fiery date workchimneyfish wrote: ↑Wed Jan 26, 2022 4:03 pm Is your House Party game updated to version 0.21.1?
Are you able to play the Original Story without problems?
Are you able to download and play any other custom story designed for version 0.21.1 (maybe try Katherine's Party or Fiery Date)?
[Complete Story] Random Party [1.3.0]
Re: [Complete Story] Random Party [0.21.1]
I'm stumped. I asked peter980 (author of Gond Bad Party, who knows modding better than I do) and he doesn't have an answer either. If you're updated to 0.21.1 (upper right of the main menu), I have no idea what the problem is.onceinabook wrote: ↑Thu Jan 27, 2022 6:26 pm I can play other up to date stories, as well as the original and my game is up to date, i do have the same issue with gone bad party as well though, but Katherines party, an fiery date work
Little update of the french translation: it's still on its way, but i found an engine issue which i can't probably fix on my own without altering a bit some sentences:
Oh hey, asshole. I {Amy:OtherGirlAction} {Amy:OtherGirl}. What makes you think you can pull that shit with me?
Part between { } is a variable. There is no big deal when it's a name or a number.
In this example, OtherGirlAction can be "heard you asking for a striptease from" which can't be translated...
Yeah, I suspected that the OtherGirlAction variable would be a problem for translation. In a future version, I will create alternate dialogue texts instead of using it directly.ttant wrote: ↑Sat Jan 29, 2022 1:33 pm Little update of the french translation: it's still on its way, but i found an engine issue which i can't probably fix on my own without altering a bit some sentences:
For now, in the translation maybe you can replace {XXX:OtherGirlAction} with the appropriate translation for "...saw you with..."? That's the fallback value for OtherGirlAction and it would make sense for all other possible values of the variable.
That's what i'm planing to do.chimneyfish wrote: ↑Sat Jan 29, 2022 2:51 pm For now, in the translation maybe you can replace {XXX:OtherGirlAction} with the appropriate translation for "...saw you with..."? That's the fallback value for OtherGirlAction and it would make sense for all other possible values of the variable.
Sadly, same goes for BoozeString, ClothingNameBottom, ClothingNameTop, etc.
In my pov, variable system works well only for firstname and numbers. All others have to go :/
French translation of 21.2.0 (untested)
- Random Party 21.2.0-fr.zip
- (803.44 KiB) Downloaded 103 times
New version uploaded in the first post and in the CSU with the following changes:
- Capped friendship checks at 95%. Even if you're BFFs, there's always a chance she's not in the mood to dance or whatever.
- Seduction and amusement checks can still reach 100%, but won't go higher
- With enough pressure, suggestible girls might start liking booze and weed more
- New special scenario: Innocence Lost. Use the tablet to access it.
- Fixed missing clothing names for Rachael and Vickie
- Corrected hint about puffing joint that mentioned "Y" key instead of "E" key
- Fixed some inconsistencies between sunglasses relationship effects and dialogue lines
There might be a bug in 21.1.2 :
While doing the french translation, i saw a change from 21.1.1 which seems odd to me:
in 21.1.1:
11111111-2e9c-45ca-baba-9443aef0897a|{Amy:NameString}
which is now (in 21.1.2):
11111111-2e9c-45ca-baba-9443aef0897a|{Patrick:NameString}
As Patrick is not part of the guests, i suppose a replacement was missing.
Anyhow, this issue is only present in Amy file. As i didn't look for context, this sentence may never be used.
Edit: translation updated, check first post for link.
in 21.1.1:
Yeah, not a bug in 21.1.2. Probably it was a bug in 21.1.1.ttant wrote: ↑Fri Mar 11, 2022 9:57 am There might be a bug in 21.1.2 :
in 21.1.1:
That sentence never gets used. Patrick is present in the Amy file as a dummy. Patrick gets replaced by Amy in the process of creating the other girls' files.
