Dancing Stephanie - A short story
Made by peter980
Version 1.23.0
Compatible with House Party version 1.2.2.1
Overview
Dancing Stephanie is a short custom story, based on the template with the same name.
Explore what Stephanie is doing, along with Ashley and Brittney, on the dance floor.
It supports both the male and female player characters.
Dancing Stephanie - Story template for creating new stories
Version 1.23.0
Overview
Dancing Stephanie is a story template that can be used as a starting point to create new stories.
All you need to do is to import the story to the CSC and start working from there.
It consists of:
Dancing Stephanie Template story file
Based on Original Story story files (from the 1.2.2.1 release).
All story-specific logic is removed.
Preserved Inspect, Take, Use With actions for all items.
Preserved Drink action for all booze and Eat action for edibles.
Preserved Hold in Hand action for booze and several other items.
"Use with" logic from each of the items is removed (since it was Original Story specific).
Preserved Open, Clock, Lock and Unlock actions for all doors, and functionality of two Key items.
Open will automatically unlock and open the doors if having the key.
Tiny Key will open the Bike Lock that bars closet doors in the spare room, and make it fall on the ground.
The terrarium can be latched/unlatched.
The Freezer can be opened separately from the fridge.
The Microwave and the Dryer doors can be opened/closed.
The hot tub can be covered/uncovered with the hot tub cover and plexiglass.
Can climb on the roof, using the gutter.
Preserved Sit action for all chairs/sofas/beds.
Preserved Sit action for the hot tub, including restriction on clothing.
Preserved Lay Down action for master bedroom bed.
Preserved all functionalities of the Camera.
Preserved abilities of the phones to be held in hand and to turn on their lights.
Preserved ability to turn on and use Shake Light.
Preserved ability to grab and throw snowballs from the Snowball Bucket if Winter Holiday DLC is enabled.
The thermostat will change the temperature.
Sleazy Sancho is mounted to the wall and can be poked.
The padlock button can be interacted with.
The whale poster can be ripped off.
Can pick up Vape and use Blaze action.
Can pick up Wizbanger Poppers and use Throw One action.
Can pick up Starbomb Box and use Throw One action. Includes changing lightning of fire pit, if thrown on it.
Beer Pong works.
Both speakers are functional as separate entities and can be controlled with TV controls or a remote to play any song.
All air vents can be opened and closed and their state viewed in the tablet app
All game characters have Inspect, Talk and Give actions (with all original story logic stripped).
The Player character radial menu has all clothing options preserved.
The Player character radial menu has all lewd options preserved.
The Player character can dance in the normal and in Patrick's style.
Added the following events on the new game start:
*Enable Stephanie.
*Display welcome message pop-up.
*Set basic dancing skill level for the player.
*Hide solo star bomb and a bloody knife.
*Hide duplicate copies of the sleeping mask, collar and rum.
*Reenable the camera (as if an SD card was inserted).
*Lock closet doors in the spare room that has a bike lock.
*Initialize speakers to play all music tracks on repeat.
Added the following events on any game start:
*Restore default bushes near windows that look at the fire pit.
*Hide gazebo star lights when playing with Winter Holiday DLC.
*Set default appearance of "pinchy boi".
*Set the correct state of the whale poster.
*Apply the correct fire pit effect.
*Resume music playback on speakers.
*Reenable music listing on the TV.
Stephanie character file
All dialog stripped exempt default greeting line (this also includes first met alternate line).
Only a single global response.
All quests, as well as any item giving logic, were removed.
Added game start event trigger on a new game that sets roaming restriction for Stephanie and puts her dancing skill to 9.
Translation
* For a French translation of the short story, check the following post by ttant
Important Notice
I do not give rights to anyone to reupload my stories with Custom Story Uploader. That right is reserved only for me.
Downloaded 9831 times - older releases
[A Short Story + Story Template] Dancing Stephanie [1.2.2.1] {CSC 1.2.2.1}
- Dancing Stephanie v1.23.0.zip
- (181.67 KiB) Downloaded 587 times
- Dancing Stephanie Template v1.23.0.zip
- (127.71 KiB) Downloaded 322 times
Re: [Story Template] Dancing Stephanie [0.10.4] {CSC 0.8.0}
I've uploaded new version (1.0.1).
Main difference is that game start event that handles environment is moved to new Phone Call character file.
I did it this way, so that creators that opt not having Stephanie in the story, can still keep all setup scripts for camera, speakers and such running, as long as they keep Phone Call character file.
Re: [Story Template] Dancing Stephanie [0.11.3] {CSC 0.8.0}
I've uploaded new version (1.0.2). This one is based on 0.11.3 original story files
Most changes are fixes to typos when inspecting objects, but other changes include new inspect description for Katherine and added interactions to second patio chair that is outside.
I may do another update when new Custom Story Creator version is out, to verify at that point if maybe I have missed something.
Re: [Story Template] Dancing Stephanie [0.11.3] {CSC 0.11.3}
I've uploaded new version (1.0.3). This one is updated through new 0.11.3 story creator.
The only noticeable change is that I've expanded on what can be done with Stephanie. So this will make this mini-story a little bit more interesting for non-story creators.
Re: [Story Template] Dancing Stephanie [0.12.3] {CSC 0.11.3}
Version 1.0.4 release
It was made compatible with 0.12.3, but is still based on 0.11.3 original story files, and was created with 0.11.3 story creator.
In future, I'll create proper 0.12.3 version, when new CSC arrives.
Also, I've added Brittney in the mix, so Stephanie does not dance alone.
Re: [Story Template] Dancing Stephanie [0.12.4] {CSC 0.11.3}
Version 1.0.5 released
Updated to work better with 0.12.4, but is still based on 0.11.3 original story files, and was created with 0.11.3 story creator.
Version 1.0.6 released
Story file is updated to be based on 0.12.4 version, so bunch of new items added in 0.12.3/0.12.4 are now available.
This also includes mechanic where locked doors automatically unlock and open, if using Open action while having key.
Also updated with 0.12.4 custom story creator.
