Page 44 of 100
Posted: Sat Nov 30, 2019 9:32 pm
You don't need to text them since that option was removed since 0.8.8.
Just talk to Madison afterwards.
Posted: Sun Dec 01, 2019 12:33 pm
Version 4.2.2 is out!
Small tweaks to tamper options, so they are much less likely to displace characters on failure, if those characters need to be at the current location, due to story.
Posted: Mon Dec 09, 2019 6:50 am
Version 4.3.0 is out!
Added hidden addition to Patrick/Rachael key ring scene, if you have some affinity with Rachael.
Increased romance meter gains when failing higher-level tempt action (should be the same as for lower tempt action now).
Options with Stephanie won't get restricted when Katherine gets to the bathroom until you talk to Stephanie about Katherine.
Tweaked Lety/Brittney scene so that putting clothes on at the end of the scene is synced correctly.
Some actions in the house will not force Katherine glasses on or off anymore.
Other minor tweaks.
Posted: Mon Dec 09, 2019 10:22 am
French translation updated as well, check first post for links.
Posted: Mon Dec 09, 2019 6:10 pm
Version 4.3.1 is out!
This is hotfix that fixes an issue where sometimes Rachael and Madison are unable to get the highest affinity with the player character.
Posted: Sun Dec 15, 2019 4:10 pm
Version 4.4.0 is out!
Highlights
BJ intimacy actions will not anymore be unlocked by solving Original Story opportunities.
Instead, they will be unlocked at the same time as other actions, based on affinity with girls.
This means that the Four Jobs opportunity is also removed.
Other changes
BJ options for Madison/Katherine during specific scenes (Simon Says, photoshoot) use regular names.
Extra option added to Katherine during photoshoot, if having proper affinity with her.
Fixed issue with BJ not working correctly, if the player character is laying down when it starts.
Separate masturbate option, which was rewarded to Rachel after completing her dares, is removed.
Additional minor tweaks and fixes.
Posted: Mon Dec 16, 2019 12:44 am
Version 4.4.1 is out!
This is a small hotfix release.
Changes
Fixed error where BJ action for Rachael would be available when it should not be.
Posted: Wed Dec 18, 2019 11:38 pm
Version 4.4.2 is out!
Reduced distance at which BJ intimacy is available, in order to prevent exploits.
Tweaked timings of transitions for intimacy scenes when there are multiple characters involved.
Tweaked behavior of characters when player character is interacting with girls that make out.
Posted: Thu Dec 19, 2019 1:56 am
I just realized that I mislabeled latest release as 4.2.2.
So I reuploaded it with correct version number that is 4.4.2.
Posted: Thu Dec 19, 2019 1:25 pm
Version 4.4.3 is out!
Fixed problem with Katherine photoshoot scene, when it was not correctly detected as naked posing in some scenarios where it should be.
Slowed down player recharge a bit to balance out some other changes that were done recently.
