[Complete Story] Battle House [1.2.2.1]
Re: [Complete Story] Battle House [1.0.0]
HexastenTv12 wrote: Tue Aug 02, 2022 9:43 am you know that each time I make a French version so that you have less work to do but each time I have the impression of adding even more to you
You can base your next version over mine if you want ;)
HexastenTv12
Re: [Complete Story] Battle House [1.0.6]
New Battle House Update : 2.2.1
- Added interaction with player and objects
- Added side quest with Ashley
- The story is compatible with House Party update 1.0.6
Proper french version was added to first post ;)
Note that the "so you want to see them I bet, breath on me and you will have a surprise at the end." sentence may be badly translated, as i'm not sure what the "breath on me" part is.
HexastenTv12
ttant wrote: Thu Jan 12, 2023 3:22 pm Proper french version was added to first post ;)
it's with the vape
In this case, "breath" should be "breathe." https://www.grammarly.com/blog/breath/
HexastenTv12
New Battle House Update : 2.3
- Added cheat codes (the mp3 above the stairs, you must select a scenario to access it)
- Added a easy mode (the sd card to the right of the laptop in the main menu)
Fyi, the french version you provided is the same zip as the english custom story.
Edit:
* fixed zip using proper version.
* fix version in first post (as it was still written 2.2.1)
HexastenTv12
ttant wrote: Tue Jan 17, 2023 2:47 pm Fyi, the french version you provided is the same zip as the english custom story.
Edit:
my bad and thank you
HexastenTv12
Re: [Complete Story] Battle House [1.0.9]
New Battle House Update : 2.4.1
- Added added a side story with Leah
Leah loved your performance at the party at Derek's. She would like to do a training session with you. That's why she invited you to her home.
You can select this scenario in the laptop in the main menu.
Proper french version uploaded on first post ;)
