[12.4] Microwave Coffee
Minor thing: using the coffee with the microwave always results in "The microwave seems to be broken. I'll have to find another way..." even after Katherine has fixed the microwave. So it's inconsistent with the inspect text which says the microwave is working now.
Re: [12.4] Microwave Coffee
Have you tried using the stove for the coffee? The microwave is for hot chocolate.
I understand how to complete the quest. I'm saying the game text is inconsistent. After the microwave is fixed, it should say something like "Microwave coffee? Ick, even Patrick wouldn't drink that."
you gotta use the kettle and the stove to warm the coffee
Per post above, I'm not asking for help. I'm reporting a minor bug. Thanks though.redwings16 wrote: ↑Thu Jan 24, 2019 2:17 am you gotta use the kettle and the stove to warm the coffee
I understand what you're saying. The inspect text and use-with text does not update contextually based on the player fixing the microwave.
Easy fix, I got you
Easy fix, I got you
Thanks! I think the inspect text actually does update correctly; it's just the use-with text that doesn't.
