[0.9.4] Bed bug [Fixed 0.9.5]
hungle
In 0.9.4 when I use console commands to make the characters have sex on the main bed they have sex by the side of it instead. This happens whether they are clothed or unclothed.
Edit: I forgot to mention that this is also the case for player/NPC sex as well as NPC/NPC sex, e.g. you end up on the floor instead of the bed when you initiate sex.
Behaviour in 0.9.3:
Behaviour in 0.9.4:
Re: [0.9.4] Bed bug
Try warping to "missionarysexspot" instead of "bedleft".
hungle
Re: [0.9.4] Bed bug
Thank you for the tip it's much appreciated but it only works for a 1v1 scenario, if you want there to be more people involved (picture below) then you're still out of luck.
Picture from 0.9.3:
Re: [0.9.4] Bed bug
Seems to be working fine now; check it out in the next release:
hungle
Re: [0.9.4] Bed bug
I've just tried out 0.9.5 and things are indeed working fine, many thanks. 8-)
Re: [0.9.4] Bed bug [Fixed 0.9.5]
No problem, we got u fam.
