Loading a save made after the Game Grumps land leads to the hot air balloon glitching into the house. Image attached. Repeatable.
-and-
Loading previously mentioned visually glitched save, in which Arin was already given 3 beers. Then trying to initiate the "Get Arin to invite Frank to the D-Club" branch. The Grumps speak their lines to each other at the same time. Then they walk into the kitchen. Dan says "You know what to do" and they remain there doing nothing. Repeatable.
Specs: https://pcpartpicker.com/user/Retnaburn ... iew=rL9cHx
Tried attaching save files but the forum doesn't accept them.
Testing branch - Loading save after Game Grumps visual and game breaking bugs
- 20210417201318_1.jpg (226.73 KiB) Viewed 4546 times
Re: Testing branch - Loading save after Game Grumps visual and game breaking bugs
Loaded the save prior to the Game Grumps arrival and played it out to the same point and the story continues as it should, so the bugs are related.
Finished the Game Grumps arc and saved. Loaded the save. Visual glitch still present.
The hot air balloon issue at least has already been fixed for the next update. Will look into the other issue, but with all the issues we've addressed with the BGC system for 0.19.3 it should also be fixed. Thanks!
Ok, cool. Is there a known issues list?
We try to post what we're 100% aware of when the Testing updates go out, but occasionally just forget to add one, are not sure that one affects all users, or do not include those that are cosmetic in nature.
In this case, I just forgot to mention it to the copywriter dood.
