[Mod] Rumble Party
For texture mods or other House Party mods. Texture mods are the only mods (other than Custom Stories) formally supported by Eek! Games at this time.
All mods posted here are user-created, and offered "as is" by those users/authors.
Any mods not posted here will be deleted immediately.
Any mod that stops functioning as intended or that unexpectedly compromises the game experience for a user or the stability of their system will be deleted immediately. Regardless of our intent to moderate, note that use of ANY of these mods is at your own risk.
Eek! reserves the right to enforce any of the above rules and/or delete mod content without warning. Create and manage your own backups.
seehofer
[Mod] Rumble Party
This mod adds support for lovetoys using intiface/buttplug.io.
It makes your toy rumble based on character dialogue, combined with your current relationship status! The more you love them, the more your device loves you.
It also tracks the players and partners movement in all the steamy hot encounters to decide on the vibrations, strokes, rotations or oscillations.
Currently it works best with "Legacy POV" (check your Game Settings).
Cutscenes are not fully integrated yet, but we're working on music sync.
supported devices
If you can make sure to donate to qdot for their hard work making the huge foundation that is buttplug.io here: https://www.patreon.com/qdot
ALT + X to STOP
Installation:
Make sure you have installed the game and at least started the game once before you continue.
  1. Download MelonLoader.Installer.exe
  2. Run MelonLoader.Installer.exe.
  3. Click the SELECT button.
  4. Select and HouseParty.exe from where the game is installed.
  5. Select the latest Version of MelonLoader.
  6. Click the INSTALL or RE-INSTALL button.
    RumbleParty.zip
    (5.01 MiB) Downloaded 131 times
After this the installation directory of the game should contain a new folder called "Mods". Then Move the downloaded "RumbleParty.dll" into this folder and start the game.
Connect your devices and off you go.
You can also find settings in your Melonloader config (HouseParty/UserData/MelonPreferences.cfg)
"intifaceEngine" value can be used to connect to the standalone intiface central app.
This is an early release, so please excuse imperfect scaling factors.
Note: Does not work with pirated versions
gharem9420
Re: [Mod] Rumble Party
i got the mod installed but cant get it connected. i have a funsr1 toy i connect it to initface but the game i guess doesnt recognize it? please help if possible thanks!
seehofer
For issues with toys its best to use the standalone intiface central app for the toy connection, and give the mod the connection string to the intiface central app via the settings under House Party/UserData/MelonPreferences.cfg
