Page 1 of 2
[Incomplete Story] The Key To A Good Time [0.8.3, tested and working on 0.9.3] {CSC 0.5.0}
Posted: Tue Feb 27, 2018 3:40 pm
by thaw9182v2
Remake of my original story, The Key To A Good Time, using the 0.6.1 editor, though since I copied and edited the files from the Original Story, it says it's 0.5.0 in Unity. I wasn't sure which one to put in the title, so I just went for the safer option.
The "story" is the same as it was before. You need to grab the towel and key from the bathroom on the ground floor, and then turn off speaker 1 (the one closer to the cough in the living room), and then either whip out your penis, or take off your jeans and boxers. Once a girl reacts, you can tell her to go and wait in the upstairs master bathroom.
Once the girls are in the bathroom, they can be told to go to either side of the bed, or to go to the foot of the bed, where they can be told to kneel and wait. They will then have a few different actions available, such as stripping or dressing up to different levels of undress, giving blowjobs, masturbating, or having sex.
With this new version of the story, I decided to rethink the original threesome system, and have expanded on it, allowing a few more things, as follows:
- Threesomes (FFM) between any two girls and the player. Once both are on opposite sides of the bed, have them strip completely, or at least go bottomless, tell one to "get started", while you "fuck" the other. When you click on the one you are having sex with, you will have the option to switch to the one who was masturbating.
- Foursomes (FFFM) have been fixed as of 2 March. In addition to the steps required to get to the threesome, have a third girl kneel in front of the bed and "get started". If there are two other girls masturbating while you are having sex with the third, you should get the option to switch to either of the other two.
With the 2 March update, most of the major bugs I found have been squashed (details in changelog). I don't know how frequently I'll be working on this; It might get 3 more updates today, it may go untouched for another few months, or anything in between. If anyone wants to expand more on this "story" in another direction, I'd be more than happy to send them the .prefab files. Just let me know through the private messages (not email), and I'd appreciate it if you could credit this story in the description if/when you upload your adaptation of it.
Changelog:
27 Feb 2018, 20:32 UTC: Initial Release
02 Mar 2018, 20:10 UTC: Update that fixes an issue where characters may not detect that the player has exposed his penis, and another issue that caused girls to keep reacting to the penis as if it was the first time they saw it every time the player puts it back in his pants. Also, the player should not get stuck having sex with the air as often. I have removed the 9-person orgies from the description, as I am still not able to make them work reliably. If I am able to fix it at some point, I'll add it back.
Re: [Incomplete Story] The Key To A Good Time [0.8.3, tested and working on 0.8.8] {CSC 0.5.0}
Posted: Tue Feb 27, 2018 10:50 pm
If you want to script switching, you must always stop intimacy action you did with original character.
This can get messy if you want to add multiple characters, since action on single one needs to check all others and for intimacy and then stop if true.
Also due to bug in 0.8.7/8, stopping the intimacy would keep moaning sound. One way to work around this is to start masturbation instead.
Posted: Wed Feb 28, 2018 11:58 am
by thaw9182v2
peter980 wrote: ↑Tue Feb 27, 2018 10:50 pm
Yeah, I have the original character switch to masturbating when you switch to another character, so that the same switching logic can be used in all directions. The issue that comes up is usually due to the fact that when you go for 3 or more girls, the ones not on the bed are quite far from the ones on the bed. Since even the movement between the girls is animated in the game, i’m guessing that the sex animations sometime try to trigger before the player character has finished moving, causing the character and the girl to start having sex through the air.
Posted: Wed Feb 28, 2018 1:29 pm
You can also use delay property to delay the action, if that would solve the issue.
Posted: Fri Mar 02, 2018 3:17 pm
by thaw9182v2
A March 2 update to this story has been uploaded to the main post. Details have been added to the changelog.
Posted: Sat Mar 03, 2018 2:13 am
by jarb01
girls still sometimes don't react to seeing your dick. i've been getting this issue in the main story too, so it's probably not your fault.
Posted: Sat Mar 03, 2018 11:46 am
by thaw9182v2
jarb01 wrote: ↑Sat Mar 03, 2018 2:13 am
Huh... good to know.
By the way, in this story, try pressing "P" as soon as you switch off the speakers, and turn to face the dining room on the spot. They should all react as they walk towards you, though there may be some delay. This was how I was able to make them all react every time while testing.
As for the bug, I'm guessing it has to do with either the "Vision" thing, or some sort of path finding bug. Initially, Madison and Stephanie never reacted to seeing the dick, while everyone else did. The two of them were also the closest to the player character when you turn off the speakers, which causes all girls to "walk to" the player, and disables their roaming using the state menu.
My theory is that they either bugged out while trying to walk to the player, since they were already at the correct place, or that their vision cone doesn't start till some distance away from them. I was initially inclined to believe the latter, because, in testing, there were also times where Ashley didn't detect the dick until the character moved a certain distance away from her in front of her. However, in contrast to Ashley, Stephanie and Madison never reacted at all, even if I sent all the other girls upstairs, put the dick back in the player's pants, walked to the dining room, removed the dick, and started walking towards the girls again.
As such, I'm pretty sure it is some combination of the two. This is why I just changed all the girls' starting locations, so they'd all have to walk towards the speakers from elsewhere. I noticed most, if not all, girls reacted to the exposed penis almost as soon as they entered the room, with the rest reacting by the time they reached the sofa.
Posted: Sat Apr 28, 2018 2:30 am
by Marc449b
thaw9182v2 wrote: ↑Tue Feb 27, 2018 3:40 pm
Changelog:
you said it's tested on 0.8.3 and works on 0.8.8 too, but it works on the newest version too (i make steam update the game by itself) so I think it's 0.9.3 I use.
Posted: Sat Apr 28, 2018 11:10 am
0.9.3 was not released yet back then
Posted: Sat Apr 28, 2018 12:08 pm
by Marc449b
ttant wrote: ↑Sat Apr 28, 2018 11:10 am
i know, i said to let him know that it also works on 0.9.3 too
