Page 1 of 2
Even Sluttier Party Re-release [0.8.8] {0.5.0}
Posted: Sun Feb 25, 2018 3:36 am
This is re-release of Even Sluttier Party from
mada7, made compatible with version 0.8.8.
Story was made originally for 0.8.3, using Custom Story Creator 0.5.0.
Conversion is done manually, without use of new 0.6.0 version of CSC.
Some steps used for conversion can be found here:
http://forum.eekllc.com/viewtopic.php?f=9&t=73
Story is left as is, as originally made by mada7, and follows slightly edited/sluttier version of Original Story from 0.8.3
Re: Even Sluttier Party Re-release [0.8.8] {0.5.0}
Posted: Sun Feb 25, 2018 3:40 am
Technical notes:
Due to the way how shyness was implemented in 0.8.7 and later, it was necessary to add Exhibitionism stat to all characters, otherwise it would default to 0, which means shy if full naked, which is not in the spirit of this story.
What I did is to set value to 50 for all female characters, which means not shy if naked, and going to hut tub topless.
This is the only script edit compared to original made by mada7.
Known issues:
If you switch different positions with girls and one of them was BJ, at the end of intimacy girl will refuse to dance anymore.
The workaround is to either not use BJ during intimacy, or if using it, to finish with BJ. This can also be used to fix the issue if already happened.
Posted: Sun Feb 25, 2018 12:48 pm
by Orphris
Is it possible to have sex with katherine in this? As far as I remember using this cs before the re-release, I couldn't flash everyone, therefore couldn't complete the mission.
Posted: Sun Feb 25, 2018 2:46 pm
^It should be pretty simple.
Hint1: Rum
Hint2: Stephanie
Flashing is not even part of this story anymore.
Posted: Mon Feb 26, 2018 10:05 pm
by SadisticIntent
Can't figure out a way to get with Vickie outside console commands.
Posted: Tue Feb 27, 2018 12:51 am
??? She should be there, right from start...
Posted: Tue Feb 27, 2018 3:02 pm
by JohnC998
Has anyone had any success with using the console to pose a girl indefinitely? I've had no luck.
Posted: Thu Mar 01, 2018 8:43 pm
JohnC998 wrote: ↑Tue Feb 27, 2018 3:02 pm
pose charactername # true should keep them posed unless something interrupts them.
Posted: Fri Mar 02, 2018 10:53 am
by JohnC998
Thanks for the reply.
Can such interruptions be suppressed so the girl never breaks the pose?
Posted: Fri Mar 02, 2018 1:54 pm
That is tricky.
You can use state command do disable roaming for characters:
state <name> 27 remove
But if there is some other active script in the game, that dictates character behavior, you are out of luck.
For example, Brittney is scripted in original story to follow Stephanie, after some events.
Or Stephanie is scripted to go where the music is, or to go to Madison, if music stops working, etc...
Or some characters are scripted to get shy in some situations and then get away from current location.
Additionally, some characters may emit "aura" that other characters need to leave their location. But that can be disabled, since I think it is also one of the states (check "help state" command).
