Page 3 of 4
Re: <HotStory> [0.19.4] {CSC 19.4}
Posted: Mon Sep 27, 2021 5:41 pm
by Orintangio
cesidio wrote: ↑Mon Sep 27, 2021 11:01 am
Nice mod. It should have an interrupt option during sex, for example you can't interrupt makeout(kissing) you have to change position.
It is possible to grope with certain position like kissing? I never managed to do in a mod, maybe it is beyond the story creator.
I agree, making out is a problem. The only thing I could do that made sense in that case was select 'eat it'. Any other option is a problem if you have clothes on. I will figure something out with it. I really set it up to select different sex positions to switch between them on the fly. As far as groping goes you need to target what you grope and making out doesn't let you target those areas. I only found two breast groping positions and will be adding missionary next update. Both missionary and cowgirl allow breast groping. None of the sex positions allow ass groping.
Just an FYI: If you have somehow forgotten to pull out you penis or remove your clothes, switch to EAT IT to get out of trouble.
In cases where sex takes too long, in the player menu select FAST CUM. This works much better if you don't want to select a different partner on the fly or switch up positions, which gives your female partner another chance to orgasm.
Posted: Tue Sep 28, 2021 1:28 am
by Orintangio
Updated to version 10
Posted: Tue Sep 28, 2021 2:56 pm
translation updated as well.
Posted: Tue Sep 28, 2021 11:13 pm
by Orintangio
ttant wrote: ↑Tue Sep 28, 2021 2:56 pm
I applaud and appreciate your work my friend!
Posted: Fri Oct 01, 2021 10:29 pm
by Orintangio
Version 11 released - no text changes
Posted: Sat Oct 23, 2021 10:25 pm
by oeswapi
I have a request; can you consider creating a section with strap-on options for girl on male/girl on girl? i don't know if that's even possible but that would make this the only story i need,
thank you.
Posted: Fri Oct 29, 2021 10:04 pm
by Orintangio
oeswapi wrote: ↑Sat Oct 23, 2021 10:25 pm
thank you.
I was thinking if I go that far, I should go for male on male as well. I guess if you don't like it, don't pick it in the menu. I will see if I can get it added for you. I can do it from the console, just not sure if CSC supports it till I try it.
Posted: Sun Jul 24, 2022 9:04 am
by daniel9999
please update to v1.0.0
Posted: Wed Oct 26, 2022 7:31 pm
by Orintangio
I checked this with the new release and found some issues, but it still worked when the player selected is a male. For some reason all male NPCs and Katherine, Letty, Brittney, and Leah are parked outside the fence in the back yard beyond the Hot Tub (not sure why the cover is on the Hot Tub or how to remove it). Other than that though the game still worked. I was working on updating the story and tried a search and replace that didn't work and corrupted the updated story.. I will need to drop back to my last updated story as a starting point.
Posted: Thu Oct 27, 2022 9:52 am
by chimneyfish
This
discord post explains what's up with the hot tub and has some hints on how to fix it. The key part is quoted below.
The Doja Cat DLC also added several obstacles/items (visible and otherwise) that you will almost assuredly want to disable/control on both New Game, and in some cases, on "Any Game" Start. For reference on how best to deal with these, we'd recommend you review the following under the Original Story (story script):
-The "Game Start Events". There is some item control here and an event trigger reference that is used to cluster further controls together
-The Player Event Triggers, namely those under the "**PLAYER - GAME START AND ENABLE**" header. This section is near the top of the Player's Event Triggers. There are five Event Triggers in total in this section that would be helpful here
As for the NPCs behind the fence, I think that's because characters no longer spawn at a default location inside the house after they activate. You need a warp to somewhere in each character's game start events to get them where you want, instead of the "loading dock." There was a post about this somewhere, too, but I can't find it.
