Running
JohnC998
Running
Currently, only the right-side shift key will make the player run IF you use the W-A-S-D keys. This works great for right-handers. Can you please add the capability to allow running using the right-shift and the arrow keys? I'm a left-hander. In fact, running would be even better if either directional key set would work with either shift key.
Thanks.
Re: Running
Next version will have a way to change the keyboard mapping.
For the time being, you can do that using another software called autohotkey.
The main idea is to remap a key to another one. So you would be able to use arrow key like you used it with left shift pressed at the same time.
JohnC998
Re: Running
Thanks for the tip.
