Re: Saved games sharing thread
Posted: Sun Nov 21, 2021 5:38 am
Save 7: Vickie's Test
1) Player is at the point where is he ready to pass Vickie's test.
2) Frank is knocked out by Derek and Patrick, and it is possible for Leah to stumble on Vickie's test and to choose to go with Leah instead of Vickie.
3) Player hooked with Ashley on her Smooth Operator path.
4) Player hooked up with Katherine.
5) Derek's Memory Lane path was started up to 3rd beer (roof scene finished).
From here, after you finish Vickie's test, you can get a special one-time intimacy cutscene with Vickie in the hot tub, or alternatively one time BJ scene with Leah.
After getting a sex scene with Vickie (instead of Leah), you will have the following repeatable threesome intimacy options available: Ashley, Katherine, Madison, Rachael, Stephanie, Frank and Patrick.
Repeatable basic intimacy cutscene is available with Katherine.
Repeatable POV intimacy is available with Ashley, Katherine and Vickie (if you did not do Leah path).
In VR, repeatable POV intimacy is available with VR Katherine and VR Rachael.
Save 8: Amy's Choice This save continues on Save 7, with two branching paths for Amy.
1) Story is at the point when you need to decide to continue Amy's Scavenger Hunt quest or abort it and pursue Chasing Amy path.
2) Player hooked up with Vickie.
3) Frank recovered from being knocked out.
4) Lety's story progressed up to a point where she searches for a female partner to hook up with.
You will have a one time BJ threesome scenario available with Lety and Brittney.
You will have the following repeatable threesome intimacy options available: Amy (if you complete the Chasing Amy path), Ashley, Katherine, Madison, Rachael, Stephanie, Frank and Patrick.
Repeatable POV intimacy is available with Amy (if you complete the Chasing Amy path), Ashley, Katherine and Vickie.
In VR, repeatable BJ is available with VR Lety (after the Lety's scene with Brittney is done).
Save 9: Amy in Hot Tub This save continues on Save 8, where Amy needs to do her last Scavenger Hunt task.
1) Amy and Brittney are in the hot tub at the end of Scavenger Hunt path.
2) Music is set up to play near hot tab and Stephanie is dancing there.
3) Player gained favor from Derek and can use it to have him flash Frank.
From here you can enjoy a spicy stripping scene in the hot tub with Amy and Brittney.
You will have a one time BJ threesome scenario available with Lety and Brittney. And Brittney will be topless in it (after you finish Amy's final task).
If Derek flashes Frank, and you opt to romance Frank, you can get repeatable a special intimacy cutscene with Frank in the bathroom. Alternatively, you can force Frank to leave the party.
You will have the following repeatable threesome intimacy options available: Amy (after you finish Amy's final task and have her stay topless), Ashley, Brittney (after you finish Amy's final task and Lety's scene with Brittney is done), Katherine, Madison, Rachael, Stephanie, Frank and Patrick.
Repeatable POV intimacy is available with Ashley, Katherine, Vickie or Frank (if you choose to romance him).
This save continues on Save 5, by advancing Vickie's storyline.1) Player is at the point where is he ready to pass Vickie's test.
