Cant Warp
Re: Cant Warp
Too bad, you'll have to go by foot to them...
Let's stop joking, and give us something more precise that "it doesn't work": What version of HP do you use ? On what system / config ? What is your current locale ?
Re: Cant Warp
Are you referring to a CSC drop-down issue or the mechanic failing to work properly in-game?
Re: Cant Warp
And if it's a start of game event, put a delay on it (0.1 to 0.3 seconds) or else it won't work.
Re: Cant Warp
sorry but i was sure this is a commen bug because all i did was
made a copy of the blank story
new event
when game starts - warp to - move target - when new game is true
I tried it with a delay and its not working
it works with items (bed, Chair) without delay and the console comand is working
by now i avoid the problem with a dialogue at the start of the game warping them
new event
Re: Cant Warp
When you complete your story, can you provide the name? Or PM it to me. If warping to movetargets after a small delay was not working, then the Game Start positioning in the Original Story itself would also not work. Our stories use the same events as custom stories, and the same core engine.
Re: Cant Warp
i tried it with a delay of 3-5 secends and it is working now ^^
sorry for the trouble and thank you for the effort
Re: Cant Warp
I use Linux Mint for the OS and use Steam to play the game and WINE when I made a custom story. I found if you give a delay it helps.
