[Not Implemented] Add random function
Currently, only CoinFlip check is implemented (50%) chance. It would be good if there is way for more gradual random function.
Re: [Not Implemented] Add random function
Yeah I can put in a ticket for this.
dev_n
Can you check on the status of that ticket? ;)
It takes a lot of effort to generate a random number with uniform probability through coin flips. Kind frustrating when you consider the outcome of the coinflip function was already determined by calculating a random number.
Yeah I know, it's annoying. I can't promise it'll get done in 0.17.x as we're dealing with a lot at the moment, but I will put it in the to-do list for 0.18.x.
Can you and Peter980 further clarify exactly what would work best? Sounds like a RandomizeIntValue game event, which will take two manually input integers, and product a random value between those two would work fine.
Yes, that would be perfect.
The special case of (0,1) would be current coinflip, while (0,100) would simulate chance in percents.
Alrighty, thank you!
dev_n
Yes (0,100) would be great, thanks!
dev_n
If it would be easier, it could be parameterless, just return an int between 0 - 100 that you could compare to with a less than / greater than.
For instance, a criterea might look like {RandomNumber LessThan 30} if you wanted a 30% chance of that event occuring.
Here is what I am shooting for. Pretty easy, we just got bogged down with other stuff. Should take care of all your needs.
PartyBob
Just popping this one back up into visibility. This function would be really useful, as the series of coinflips method is really inefficient for getting randomization.
