This is re-release of Even Sluttier Party from mada7, made compatible with version 0.8.8.
Story was made originally for 0.8.3, using Custom Story Creator 0.5.0.
Conversion is done manually, without use of new 0.6.0 version of CSC.
Some steps used for conversion can be found here:
http://forum.eekllc.com/viewtopic.php?f=9&t=73
Story is left as is, as originally made by mada7, and follows slightly edited/sluttier version of Original Story from 0.8.3
Even Sluttier Party Re-release [0.8.8] {0.5.0}
- Even Sluttier Party Re-release [0.8.8].zip
- (502.98 KiB) Downloaded 8705 times
Re: Even Sluttier Party Re-release [0.8.8] {0.5.0}
Technical notes:
Due to the way how shyness was implemented in 0.8.7 and later, it was necessary to add Exhibitionism stat to all characters, otherwise it would default to 0, which means shy if full naked, which is not in the spirit of this story.
What I did is to set value to 50 for all female characters, which means not shy if naked, and going to hut tub topless.
This is the only script edit compared to original made by mada7.
Known issues:
If you switch different positions with girls and one of them was BJ, at the end of intimacy girl will refuse to dance anymore.
The workaround is to either not use BJ during intimacy, or if using it, to finish with BJ. This can also be used to fix the issue if already happened.
Known issues:
Is it possible to have sex with katherine in this? As far as I remember using this cs before the re-release, I couldn't flash everyone, therefore couldn't complete the mission.
^It should be pretty simple.
Hint1: Rum
Hint2: Stephanie
Flashing is not even part of this story anymore.
Hint1: Rum
Hint2: Stephanie
Can't figure out a way to get with Vickie outside console commands.
??? She should be there, right from start...
Has anyone had any success with using the console to pose a girl indefinitely? I've had no luck.
Thanks for the reply.
Can such interruptions be suppressed so the girl never breaks the pose?
That is tricky.
You can use state command do disable roaming for characters:
state <name> 27 remove
But if there is some other active script in the game, that dictates character behavior, you are out of luck.
For example, Brittney is scripted in original story to follow Stephanie, after some events.
Or Stephanie is scripted to go where the music is, or to go to Madison, if music stops working, etc...
Or some characters are scripted to get shy in some situations and then get away from current location.
Additionally, some characters may emit "aura" that other characters need to leave their location. But that can be disabled, since I think it is also one of the states (check "help state" command).
