Game not loading properly [1.0]
kingmecha42
Contact:
This has happened multiple times in a row. Run Steam and load the game. Play through either gender, save and load games, and restart the game. No problems. Shut down the game and turn off the laptop. Turn on the laptop and run the game. Start a new game regardless of the gender. Instead of running the intro video it loads the player into the apartment and the player is stuck in this falling animation. I can move around the apartment but can't interact with anything. If I pause and click restart it loads me into the house except no NPCs and can't interact with anything. Sliding door is closed and the trail of oil from the garage to the backyard is there. Exit the game and try again with the same results. In Steam I tried verified the game files and it redownloads a few files. Run the game and same issues are still there. If I uninstall the game and remove all files from the computer then reinstall the game it then works. As soon as I quit the game completely and restart the computer the same glitch returns.
System Specs:
Asus G15 G513QE-DS99-CA
Ryzen 5 5900HX
GeForce RTX 3050 Ti 4GB
32GB DDR4 @ 3200MHz (upgraded)
Intel 660p 1TB (OS, software, and game launchers)
WD 750 SE 1TB (games install drive)
Running Steelseries GG for Arctis 5 USB headphones
Windows 10 Home 21H2 (fully updated), all drivers current
Main: 11600K/6900XT/32GB(ram)
Laptop: 5900HX/3050Ti/32GB(ram)
VR: 3700X/3060Ti/32GB(ram)
markiez
Re: Game not loading properly [1.0]
Hello!
From which store did you get the game?
Please try these troubleshooting steps:
-If it's from Steam, can try verifying your file integrity?
-Are you using One Drive by any chance? Can you try turning it off?
-Can you try turning off your antivirus and running the game again?
If all fails, here are more suggestions:
https://steamcommunity.com/app/611790/d ... 8559406205
If none of those work please provide us your play log which you can find here:
%USERPROFILE%\AppData\LocalLow\Eek\House Party\
kingmecha42
Contact:
Turns out it was Unity that was causing the problem. It was another Unity based game install that was causing the problem. Installed Unity directly from their website and all games are working.
