Back after a long hiatus mostly due to the NPC/NPC intimacy not being stable enough to make a story that isn't super buggy.
For those unfamiliar with what this is it is as much of the original story as possible but:
- only girls
- repeatable sex with all the girls is possible in a single run
- all the girls have sex with each other at least once
- over the top sluttier backstories for as many of the characters as possible
- negative dialogue options replaced with positive/sluttier responses
- easier to get girls naked and having sex
What I haven't touched and/or am planning on working on for later but didn't want to delay releasing this over so you can do them but I can't guarantee they work/won't break the flow of the story:
- Amy not completing the scavenger hunt
- Drunk and disorderly quests
I also added in a silly easter egg type thing where if you use the right items with the fire pit in the right order everyone becomes naked and able to have sex right away.
If there's any bugs I missed (I probably did as testing this is a nightmare) let me know and I'll do my best to fix them and in return with each batch of bug fixes I'll reveal another item to put into the fire pit
Edit: First update is in should address bugs mentioned thus far.
First item that can be used with the fire pit is the USB Key
Second item is credit card
Translations:
French
[Incomplete Story] Sluttier Party Returns [0.14.4]
Sluttier Party Returns v1.2.zip
- Bug fix for ashley humiliation quest
- (1.47 MiB) Downloaded 13636 times
Re: [Complete Story] Sluttier Party Returns [0.13.3]
Yeeeeesssssss!!!
"Original Story.story" is still present in the zip file you made. i guess this file is useless (or should be).
I'll start the translation soon.
It was working fine on my machine since it has both the custom and original and none of the characters reference original but just in case I rezipped it without that file
edit: for real this time
So played through this story now but i can't seem to be able to sleep with ashley or madison, and never got to have sex with stephanie either,
don't really know if you should be able to or not but i will play through it one more time and see if there is any difference.
the prodigy has returned!!!! I sincerely thank you for this!
I assure you there is a way to do that and all that is connectednarrebasse wrote: ↑Sat Jul 13, 2019 7:29 pm So played through this story now but i can't seem to be able to sleep with ashley or madison, and never got to have sex with stephanie either,
But but... why now mada7, when 0.14.4 is around the corner? With all those new poses and everything...
Bad timing i guess, and even if 14.4 is around the corner, the csc for that version might not be ready at the same time.
Nonetheless, i think it's best to release something for 13.3 to fix any existing issue before upgrading the story to 14.4.
I've been working on this since 13.3's CSC came out so come hell or high water I'm getting this out there. I'm gonna upgrade this once the 14.4 CSC comes out to include Lety and see if any of the new wall sex positions make sense for G/G sex. The doing everything from scratch model that I've been going with for so long isn't gonna work anymore (the game is too big for that) so it doesn't matter how soon the next version comes out
