Reuploading just for the hell of it.
Just a refresher. This is the story with the
- Stephanie x Brittney threesome
- Amy is a Model story
- Rachael is... Something story
- Vickie has a Patreon story.
If you've played this before then I have made ZERO changes to it. Nothing new.
I believe this is a "stable" story when played on 0.8.3 but I completely forgot. What I DO know is that 0.8.8 absolutely HATES this story. Almost nothing works correctly.
I've been busy so I haven't had time to write anything new.
Sorry, guys.
[Incomplete Story] <PicoDeGallo's Unnamed Incomplete Story Reupload> [0.8.3???] {CSC 5.0}
- X.zip
- (126.04 KiB) Downloaded 2169 times
Re: [Incomplete Story] <PicoDeGallo's Unnamed Incomplete Story Reupload> [0.8.3???] {CSC 5.0}
I have started to convert your story for 0.8.8, and with permission if I get it to work would I be allowed to post a link to the conversion?
so far during playthrough without conversion all ive noticed as a problem is vickie when summoned, refuses to leave her spawn location causing the path to lock up, i have however once i upset rachael got her to start wandering around and eventually progressed but rachael's dialogue was ruined for the rest of the game.
another issue which im not sure if it is a feature or not is to do with items (alot of alcohol is required) and i find there only to be enough alcohol to progress one path only, making the threesome feature seemingly impossible, because both brittany and stephanie require rum to finish either of their quests, and unless im missing something, a second bottle of rum cannot be obtained because frank is too aware even if out of sight, but both of these could be problems that are due to incompletion of story
By all means, if you can find a way to fix anything please feel free to do so. I'd honestly be honored that you did that.djfunnyre wrote: ↑Mon Feb 26, 2018 9:57 am I have started to convert your story for 0.8.8, and with permission if I get it to work would I be allowed to post a link to the conversion?
Also, just like in the main story, I've rationed the booze so you can't get ALL the endings in a single playthrough. This was intentional. But please feel free, if you can, to edit the story as you see fit and make it so the girls require less alcohol to get the endings.
I made this custom story because it was fun and interesting to try programming something for the first time. So have at it and do whatever you want to do with this.
Thanks again!
Take a look at the guide here:
http://forum.eekllc.com/viewtopic.php?f=9&t=73
While most of it focuses on how to make CSC story work without CSC, by converting it to readable JSON (so it can be manually edited even without CSC release), at the end of the guide it has section about parts that need to be changed for 0.8.3 stories to be compatible with 0.8.8.
peter980 wrote: ↑Mon Feb 26, 2018 3:37 pmTake a look at the guide here:
"Id": "17a47972-900e-4c39-b213-dcfd6afa351f",
"AddRemoveAction": "Add",
"BodyPartValue": "LeftHand",
"BooleanValue": "True",
"Character": "Vickie",
"Character2": "",
"CombatOption": "Fight",
"Criteria": [],
"Delay": 0,
"DialogueAction": "Trigger",
"DisplayInEditor": false,
"Enabled": true,
"EventTriggerOption": "PerformEvent",
"GameMessageType": "CenterScreenText",
"SendEventOption": "None",
"IntimacyOption": "SexualAct",
"ItemAction": "SetEnabled",
"Key": "",
"LookAtTarget": "Character",
"ModificationType": "Add",
"OnOff": "On",
"OpenClose": "Open",
"PlayerOption": "Inventory",
"QuestAction": "Start",
"RelationshipType": "Friendship",
"RoamingOption": "Allow",
"SocialModificationType": "Mood",
"SortOrder": 0,
"StartDelayTime": 0,
"Type": "WalkTo",
"UseConditions": false,
"Value": "Rachael",
"Value2": "",
"WalkToTargetOption": "MoveTarget"
EDIT: ive also tried manually forcing her to walk and continue the story with her talking to rachael, but for some reason her and rachael just refuse to talk. except for the one freak scenario where I upset rachael after summoning Vickie and suddenly they wanted to talk. I'm also a little bit lost as to how you import new character files youd like to edit with the editor because I feel that might solve the problem or atleast make the issue more visible. I'm also new to this game and its file/coding structure, and haven't been able to use the outdated tutorial with any luck. seeing as when I load the scene like youre supposed to do first, I don't get any results
Have you replaced this line in Vickie character file:
"Type":"EnableNPC",
This command does not exist in 0.8.8, and is most common reason of breaking scripts.
"Type":"EnableNPC",
it was already replaced, I ended up finding a line in madisons file after her dialogue while using the csc that made a call that essentially doesn't have any effect. I had to stop work yesterday due to my evening plans, but I think it might solve the issue. otherwise I might end up rewriting Vickie rachael and madisons interactions. cause amy for some reason is referenced a lot when I was sifting through dialogue even though amy has no effect. but we will see.
Re-Reuploading as ive decided to help make this story just a tad more complete and functional.
This Story is entirely the work of PicoDeGallo. This is just a re-upload of his re-upload with some minor functionality changes.
Minor changes include:
- complete port of files for use in CSC 6.1, with use of guide made by peter980
- fix for Vickie becoming locked in place, Vickie will now properly begin searching for rachael at the appropriate time
- X.zip
- (252.78 KiB) Downloaded 1061 times
Is there a walkthrough for this story?
