[Complete Story] Gone Bad Party [1.3.1]
Re: [Complete Story] Gone Bad Party [0.18.2/0.19.2]
Version 6.9.1 is out!
For 0.18.2 version of House Party
Changed a bit condition when the player is able to change sex poses if partner already had an orgasm, to fix rare situations where the player would be blocked from changing poses when not intended.
Fixed issue where Stephanie that has gone skinny dipping would still react to turning off speakers.
Here is the 0.19.2 Beta 3 release of Gone Bad Party:
https://forum.eekllc.com/viewtopic.php?p=1288#p1288
Compatible with the 0.19.2 version of the game. Available on the testing branch on Steam beta.
Fixed issue where Leah would not avoid player after failed tempt attempt.
Starting Simons Says opportunity will gracefully fail The Muse and other related opportunities.
zwoggel2k
Re: [Complete Story] Gone Bad Party [0.18.2]
I can only see the version for HP 0.19.2 - is this GBP compatibel with 0.19.1?
peter980 wrote: Wed Mar 10, 2021 3:18 am Here is the 0.19.1 Beta 1 release of Gone Bad Party:
It is a first release compatible with the 0.19.1 version of the game.
Currently, 0.19.1 is only available for Patron alpha tester backers but hopefully will be available on Steam in a couple of weeks.
Main changes
Updated story to match 0.19.1 version of the game. This will make Gone Bad Party a bit easier due to change done in Original Story to have the option to tell girls to hang at specific places in the house. With that said, all around, it should be a positive change. You do need to get some friendship points with girls to be able to use this option.
Updated "the power" of the spoon. It is triggered differently, but should now affect all girls.
There are also some clothing swapping additions:
Added ability for Katherine to switch to alternate panties. Related to this, the scenario, when she can hang in the hot tub, does not require maximum affinity with her anymore.
During the dance party, if Derek is invited to join, added an option for Derek to switch different outfit.
Important notice
The custom story version of Gone Bad Party has new sexy cutscenes disabled, in places they were used in Original Story.
This is because as of 0.19.1 these cutscenes are broken when run from custom stories (they will start, but some events in them will not function correctly). On the other hand, the mod version of Gone Bad Party will have them working, exactly as is in Original Story.
And just to avoid confusion, all Gone Bad Party specific content still uses classing sex scenes, and not new sexy cutscenes, regardless of the version used. The main reason for this is that so much of Gone Bad Party mechanics depend on interactivity, which is not available with sexy cutscenes. This may be slightly revised in the future. For example, I may consider adding an option to trigger sexy cutscenes in some situations, but that is all in the future.
0.19.1 version was replaced with 0.19.2 version and not available anymore for download.
0.19.2 version of GBP will not work with 0.19.1 version of the game.
If you have access to Patron as an Alpha Tester, then download 0.19.2 from there. Otherwise, wait until 0.19.2 arrives on Steam (in the testing branch), which may happen very soon.
Another alternative is to play with 0.18.2 version of GBP on Steam, which has 0.18.2 version of House Party.
Here is the 0.19.2 Beta 4 release of Gone Bad Party:
Fixed issue where skinny dipping option for Stephanie is unlocked slightly earlier than intended.
Fixed issue where Vickie will not go back to hot tub seat if she leaves the seat before she proposes to test your endurance.
Version 6.10.0 is out!
Added a major change to Simon Says opportunity.
It has now different unlock steps and the context of the story is modified to remove some darker undertones.
Also, you will not be able, anymore, to access the original version of Simon Says, if you try to start it before inviting Vickie to the party.
Other changes:
You can not have intimacy with Madison anymore, even if having an affinity with her, if she wants to kick you out of the party. You need to calm her down first.
Fixed issue where "relax" option was available during intimacy with Madison in some situations, during Simon Says encounter.
Additionally, the strategy guide was also updated.
Here is the 0.19.2 Beta 5 release of Gone Bad Party:
Major change
Added the same changes to Simon Says opportunity, as done in the 6.10.0 version of Gone Bad Party.
Other changes:
Fixed issue where Rachael could stay stuck with phone in her hand, after her original story intimacy scene in the bedroom, in some situations.
Here is the 0.19.3 Beta 1 release of Gone Bad Party:
It is a first release compatible with the 0.19.3 version of the game.
Currently, 0.19.3 is only available for Patron beta tester supporters, but hopefully will be available on Steam in a couple of weeks.
Beta 5 for 0.19.2 is still available for those using Steam, as well as the current 0.18.2 compatible version.
Added ability to repeat new Rachael's and Vickie's sex cutscenes.
Reworked how player recharge rate works. Instead of having it be twice faster than normal, it will start with default Original Story speed, and get increased over time until it gets around 3 times faster.
Re: [Complete Story] Gone Bad Party [0.18.2/0.19.2/0.19.3]
Version 6.10.1 is out!
Fixed some bugs in the latest rework of Simon Says opportunity.
Here is are the 0.19.2 Beta 6 and 0.19.3 Beta 2 releases of Gone Bad Party:
Compatible with corresponding 0.19.2 or 0.19.3 versions of the game.
Currently, 0.19.3 is only available for Patron beta tester supporters, while 0.19.2 is available on the testing branch on Steam beta.
Fixed issue where the player would not disrobe when replaying Vickie's cutscene (0.19.3 Beta 2 only).
