[0.8.8] Brittney will have different preference for hot tub based on older of truth or dare
In truth of dare from Amy quest, Brittney can remove bra and panties when in hot tub.
Based on this, Exhibitionist stat will change (in debug log, logged as personality change), which will control with what is Brittney comfortable when in hot tub from that point and in future (having both bra and panties, just panties or fully naked).
What I've noticed is that removing panties changes this stat to 100, and bra to 40.
So if you finish the quest by going panties then bra, final stat will be 40.
But if you finish by going bra, then undies, it will be 100.
I'm not sure if this is intended way for this to work. I assume removing both should lead to stat of 100, regardless of order.
Re: [0.8.8] Brittney will have different preference for hot tub based on older of truth or dare
Yeah this should equal out the same either way. Thanks!
